Question about Sony VAIO PCG-K25 Notebook
Vaio smart network, pcg 6y2m. When not connected to cable, the wireless wont work, switch is on, no wifi sources detected. laptop cannot now be used wirelessly?
6ya staff
SOURCE:
shaky120
John Anderson
  • 310 Answers
SOURCE: DO I have wireless?
Hi, im sure the PCG-K315M dont have a built in wireless card, You can buy a Usb wireless card for about 20-30 pounds from any shop. If your laptop did have wireless onboard there should be a switch on one of the sides of the laptop,
Have a good christmas
John
Posted on Dec 11, 2007
Anonymous
  • 77 Answers
SOURCE: Wireless Network stopped detecting ALL local networks
Hi, Have you installed the driver for your wireless card since you re-formatted?
Right click on my computer and go to properties, select device manager. all of your hardware will be listed there. are there any yellow question marks? these are devices that need drivers.
Your wifi card will probably be called 'network adapter'. go to the sony vaio website and download the right driver for your wifi card
Posted on Feb 20, 2008
drlalitv
Lalit Varadpande
  • 488 Answers
SOURCE: vaio model pcg 4a1p
see this:http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Posted on Oct 28, 2008
Anonymous
SOURCE: Sony Vaio laptop unable to detect wireless access point
CompuLayne: Hello bluebells953
Netgear is quite tricky as is with all other routers, but I don't think the router is your problem. Try to do the following.
1) Turn off Vaio laptop
2) unplug router
3) unplug modem
4) plug back in modem - wait for it to boot up
5) plug back in router - wait for it to boot up
6) turn back on the Vaio - log in and see if it sees the SID. If it isn't broadcasting, you might have to enter it in manually and select connect to non broadcasting network
www.compulayne.com
www.compulayne.com : "We Fix Computers in 48Hrs! : We Are That Easy"
Posted on Feb 28, 2009
ariyoso
ari yoso
  • 145 Answers
SOURCE: Sony Vaio Wireless switch
if its not detected, then it is not enabled or not installed correctly..
try to reinstall the driver provide from the CDs and then enable it
thats all the problem i think
Posted on Jun 28, 2009
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
No matter if secure or not will not connecet to wifi
Hope this helps
Nov 19, 2012 | Sony VAIO VGN-N325E Notebook
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
? How/where to turn on wireless internet in Sony Vaio laptop, model PCG-3A8P
there is now Sony Vaio Laptop available with model number PCG-3A8P. Please provide the correct model number so that we can search for user manual for detailed information.
However wireless can be turned on by switch available on the sides of the laptop or on front of the laptop.
Jul 06, 2011 | Computers & Internet
Unable to connect my vaio to the internet, help
Lets start from the basic troubleshooting steps.
Things to confirm:
1. Confirm that the Ethernet cable inserted properly to the Ethernet port of the Computer.
2. If it is using Wireless network, confirm that Physical Wireless Switch is turned ON and the LED is glowing.
3. Confirm that the Wireless is turned ON in Smart Wi Utility.
If you confirm all the above, go for the further steps:
Uninstalling and reinstalling the driver could resolve this issue.
1. you can find the Ethernet driver here
2. Also find the Wireless LAN driver here
3. There is an update available for the Wireless Adapter Manager here
Sep 19, 2010 | Sony VAIO PCG-K35 Notebook
No network
if you are on a wifi zone it must be detected by your laptop if not maybe your network connection setting for detecting wifi is off. try changing the settings of your network connection. and change it to auto detect the network connections
Aug 10, 2009 | Sony VAIO GRZ610 Notebook
I have a sony vaio PCG-7141L with WI-FI but I can't connect to internet due to a secure network password, what can I do?
Firstly, are you trying to use your wireless internet or someone elses?
Because if it's someone elses, thats exactly why they've put the password on so that other people can't use their connection.
However, if it's your wireless network you're trying to connect to, then it would be worth using your wireless cd software to change your password to something you know or to take it off completely (not reccomended as others can use your connection). You can put the cd in your own laptop and change the password.
Hope this helpe =]
May 09, 2009 | Computers & Internet
DO I have wireless?
John
Dec 11, 2007 | Sony VAIO PCG-K25 Notebook
Vaio laptop VGN-BX540B user
you should only need to enter the WEP key and get youre friend to remove your mac address. You may also need to refresh the ip address of your wireless card, so go to control panel>network connections>right click to properties>TCP/IP line>properties and ensure 'obtain ip address automatically' is ticked, then reastart your pc. Or you can also click Start>Run, then type ipconfig /flushdns, so as to renew your dns and ip address.
Aug 22, 2007 | Dell Inspiron 6400 Notebook
Sony VAIO PCG-K25 Notebook Logo
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
