Question about Ricoh Aficio 2018D All-In-One Laser Printer
I have ricoh aficio mp 1600Le photocopier machine. printer and copy both switches displayed by red while power on of the machine. suggestions please!
Posted by Sankar Rai on
quennie732
  • Ricoh Expert
  • 422 Answers
Push the red button and see what it says to do
Posted on Oct 02, 2013
5 Related Answers
Anonymous
  • 78 Answers
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
Anonymous
  • 87 Answers
SOURCE: ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Anonymous
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Posted on Oct 11, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2008
Anonymous
SOURCE: Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Posted on Feb 27, 2009
How to adjust Heat in Ricoh Aficio MP 2000l2
what problem does it gives when photocopy machine get under light.it that true it give dark on the top of the paper
Jun 20, 2013 | Ricoh Aficio MP 1600 Black and White...
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
Aticio mp 1600le Driver file download
Go to www.ricoh-support.com and you will find that to download for free.
See you!
May 12, 2011 | Ricoh Aficio MP 1600L Black and White...
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I need ricoh aficio mp 1600le driver, how do i get into.
Thanks, Joe
Nov 11, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ricoh Aficio 2018D All-In-One Laser Printer Logo
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
