SOURCE: I have the doro flip
Roberta, I work with Consumer Cellular and it is likely that a new phone will resolve you issues. If you email us at [email protected] we will have a service representative contact you to discuss your options. Thanks!
SOURCE: I did not receive a User's Manual with my Doro
You can download and print the complete instruction manual for Doro PhoneEasy 410 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
SOURCE: I am trying to get an online instruction manual
You can download the User manual for your mobile Doro PhoneEasy 410 from here http://www.connevans.com/instructions/40gsm410.pdf
Please rate if this solution helped you, thanks!
SOURCE: sim slot broke when I
Hello there, when the sim slot breaks you would have to replace the units main board. The main board is usually the main component of the phone system and uses the sim as the main connection to the network. To get the replacement would determine your location but usually the best place to start looking is your local dealership.
Hope this support has been helpful?
Thank you for visiting FixYa.
SOURCE: Doro PhoneEasy 410 some buttons won't work on keypad
It maybe a flex problem or keyboard problem. The reason why I said it maybe a flex problem is because flip phones are fond of having flex problems because of the constant open and close of the flip. It makes the flex wear/worn out.
And it maybe a mere disconnection.
Which ever the case maybe, the phone needs to be disassembled in order to check/know what's wrong.
Regards.
