In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
?? The "+" (plus) character (by pressing
key)
?? Your Country Code( "64" for New Zealand)
?? Your local area code minus any leading "0"
?? A space
?? Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
?? You cannot enter a hyphen in the number.
To enter a space press once between numbers.
?? The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
