Refrigerators Logo
Mario Marinelli Posted on Sep 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove evaporator On model # KSCS23FVSS01 I need to replace the evaporator tray. Does it come out from the front or back and what else do I need to do?
Audrey Hanks
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 124 Answers
  • Posted on Sep 16, 2013
Audrey Hanks
Expert
Level 2:
New Friend:
Greenhorn:
Answers
124
Questions
0
Helped
25060
Points
297
IT usually unlatches at the back and then you just have to puull it out the front.
2 Related Answers
Anonymous
  • 135 Answers
  • Posted on Sep 01, 2009
SOURCE: removing evaporator tray from kenmore side by side
Can you pull it out the back or the bottom? If not, you will have to remove the filter casing. they are built as if the tray will never break.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Feb 10, 2010
SOURCE: I have no way to remove the evaporator tray from
There not really made to remove. If you need to clean it, just reach where you can with a rag. Pour some bleach in it to kill any mold and fungus and soak it out with the rag.
If it has a leak, dry it out and patch it with some epoxy.
Why else would you want it out.
1992 dolphin rv duotherm ac still leaking after cleaning the drain tray holes
Have you checked evaporator fins/coils at front to see if it is those that are frosting up and need cleaning? Also make sure return air and cool air aren't mixing. If some cool air is getting in to return air, from other side, it will cause condensation as well. Some older models did suffer from cracks in drip tray as well. That requires removing cover on top and looking and sealing cracks in plastic drip tray under evaporator and condensor etc. Sometimes it works . Clean well and use good sealant if that's the problem.
Water drips from the back upper area inside the refrigerator. Sometimes I find a small puddle of water on the floor. It is only 6years old. Model CTB1821ARW
Look at the back wall of your fridge and at the top centre you will see a small plastic tray about one and a quarter inch square, this is part of the drain system for the freezer defrost cycle, you will find that the drain tube from this tray is blocked with debris from the freezer.
To clear the blockage:
At the outside rear of the fridge you will see a rubber tube that runs down the centre and disappears under the lower section where the compressor is located, pull off the grill below the fridge section door at the front of the unit, locate and remove the water evaporation tray, locate the the end of the aformentioned rubber tube, insert the end of a water filled baster into the end of the tube and hold it securely in place with one hand and then squeeze the baster bulb with the other hand to force water up the tube, you may have to do this more than once but it should clear the blockage, if not you may have to use a short blast from a air hose.
When you replace the evaporation tray ensure that the end of the rubber drain hose is located in the tray.
2answers
Noise from condenser fan. I cleaned the blade and the surronding area. Put some w-d 40 but the noise is still there. It is cold. Should I replace the motor? how hard is it to do? kenmore coldspot...
Go to www.searspartsdirect.com enter your model number and select model number search.
Here you can see a diagram of the unit. The fan motor cost 95 dollars.
It depends on the type of noise it is making.
These motors when failing tend to hum when trying to start which is a sign of a dry bearing.
Rattling sounds or ting ting ting sounds are either a lose fan blade (check the cheap retaining clip on the front of the shaft .. it may have wiggled forward causing the blade to wobble) or a lose mounting screw.
Also I can't tell from the diagram how close the fan is to the drip tray(tray evaporator) These fans not only aid in removing heat from the condenser.. they help evaporate the water in the drip tray.
If you remove the motor.. have it tested before replacing it. At a hundred bucks it's worth a trip to a good electric motor shop.They generally will test it for free.
If you are able to determine the voltage and hook it up out of the cabinet you may save yourself a trip.
Chances are it's a lose mounting screw or that front blade retaining clip.
Best of luck!
Water is leaking from time to time in the front of the refriderator. It's not the water feed.
Your problem is likely that your freezer has a blocked drain which doesn't allow the water to drain to the bottom of the evaporator pan under the fridge. The lower backing INSIDE the freezer needs to be removed and the plughole cleared. Best to use a hairdryer and your fingers to remove he pool of ice buildup. Try not to use sharp objects as this can dislodge or break essential plastic pieces. Water should now drain from condensor coils during defrost mode out the drain and into the evaporator tray under the fridge. (melted water is simply evaporated away by the warm air which comes from your compressor and out of the front bottom of your fridge.)
I Hope this helps. Good luck
2answers
Leaking as if there is no evaproration tray. Also freezes in the refer, not freezer section.
please provide your make and model number so I may provide you with a free solution.
I need to remove the evaporator tray from underneath.
Don't know what frig you have, but many slid out the front and a few slid out the back. The front grill is clipped in place. So you can just pull up on it and then tray will be easy to find.
Water tray fills up with water and leaks out
Drain stopped up. Remove the front panel. Run a wire from the bottom front of the evaporator coil toward the back to unstop gook. Or clean out drain.
Removing evaporator tray
take toekick off front bottom of unit tray is just under the front of the unit
careful there is water in tray
1helpful
Removing evaporator tray from kenmore side by side
9helpful
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
