SOURCE: Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
SOURCE: Bose 901 VI speakers used with sub woofer and Bose mo. 141 rear speakers
just connect 2 speakers to each output.
SOURCE: Will Bose 901 active equialiser connect to SONY AV1100 Receiver
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
SOURCE: Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
SOURCE: bose 901 equalizer hookup
I had the same problem- I have a Pioneer VSX-518 and Bose 901 series IV. My receiver has no "Tape Monitor", so after trying different hook ups, I went and bought a "3 input video switcher" (about $10.00) I run my STB (cable box), my PS3 and my computer through the inputs of the switcher (just the audio L/R) then the output to the Bose EQ input, then from the Bose EQ output to my receiver input (I chose to use the TV/DVR input). Now I just have to select which source I want to listen to from the switch, make sure the receiver is set to TV/DVR and I have fantastic sound via my Bose 901s. With this hookup, I have my 3 componets video connected to my HDTV via HDMI cable. It works for me. Hope this helps.
