Question about Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
Posted by shannon on
Arcticold Refrigeration Ltd
  • Official Brand Answer
  • 73 Answers
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Posted on Mar 10, 2014
3 Related Answers
Anonymous
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
rickead1
Rick Ead
  • 1998 Answers
SOURCE: model is rm 2350 it
there has already been a post on this on another site on what the problem may be have you looked at this click this link http://www.gasrefrigeration.net/works_on_electricity_but_not_on_.htm after you go through these tests message me back if any of the tests fail Thanks Rick
Posted on Mar 04, 2011
rockmeister
Rockme
  • 2047 Answers
SOURCE: My domestic rm 2620 shuts
If your unit keeps on going off immediately after putting it on this problem is as a result of a couple of things. Firstly this unit is made to support voltages of 120 - 110 if your location supports 220volts then the unit might have been damaged and would need a lot of work and an expert to handle it.
But if not then the power module or the PCB conductor or thermistor conductor is responsible for the problem and might need changing. Usually it is advicable to get an expert to check the unit and determine exactly which of them or if both of they all have to be replaced.
Hope this support has been helpful?
Posted on Jul 11, 2011
I have a Domatic RM 2852 in my RV. The freezer works fine but the refrigerator won't cool to 40 on electricity. It cools fine on gas.
You need to unplug the heating element from the circuit board and using a digital multi meter check the ohms. You should read approximately 44 ohms +/- 10%. If it is out of range change the heating element.
Aug 15, 2013 | Dometic RM2852 Refrigerator
The refrigerator is not getting power. The plug checked out good as well as the fuses with the volt meter. It is a domestic rm 2652 camper refrigerator.
If all the electrical components are fine then it has to be the motor for the refrigerator. It may be seized or burnt out...therefore it will not work and will need to be replaced.
Oct 12, 2011 | Electronics - Others
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
I got a RM 2852 IN A 5TH WHEEL. It will work fine on gas,but 110v does not work,Any suggestions? Thanks,David
We were told that its a faulty control board on most Rm2852 units. a factory defect.
Ours did the same thing first the gas would not stay on to cool but the unti worked fine on electric...now the electric is not working...the heater gets hot and burner comes on but does not stay on..they system shuts down..and will not cool. .
Jan 29, 2011 | Dometic RM2852 Refrigerator
Zanussi zbf 760
Gently but firmly pull one of the other buttons out and use that to reset it... you can buy new buttons on ebay
Oct 03, 2017 | Zanussi ZBF660 Electric Single Oven
Refrigerators Logo
253 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Paul G
Paul G
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
