SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
