GE JVM1660 Microwave Oven Logo
Posted on Sep 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light failures We have now had light 4 failures of the overhead bulbs ...part# WB36X10003. These bulbs are expensive and it feels as tho we are feeding a bottomless pit. Is there another bulb that replaces this bulb? I did note that on a prior question someone mentioned using a 20w halogen. Thanks
  • dshaw822 Nov 15, 2008
    I have a GE JVM1640WB007 over range microwave. It's been a great microwave with no problems until about a year ago. One of the bulbs under the microwave burnt out and we replaced it. A couple of weeks go by and the other bulb blew. We replaced that one also. Again, a couple of weeks go by and a bulb goes out again. We replace it again. This has been going on for a year. What is the deal?
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Sep 22, 2007
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4489477
Points
21748
The bulb should be squeaky clean prior to installation. If any oils from the skin get on the bulb (or grease from cooking) that will shorten its life considerably. Always use the hood fan when cooking on the stovetop to prevent buildup of grease or moisture inside the microwave controls or cooktop lights. It might be that the door is being slammed while the bulbs are on - that can shorten their life, too. You might visit a home center (Home Depot or Lowe's, etc.) and see if they have any higher quality non-Chinese bulbs. Always be sure to disconnect power from the microwave completely before removing or installing the bulbs. Failure to do so can damage the control board. We repair a lot o control boards because of this type or failure.
JVM1340 lights not working
Behind the top grill above the door is an access panel to change the light bulb. If the bulb is good but light still don't work, its possible the door switch is bad, but normally if the switch is bad the turn table won't work either. Most likely just a bad bulb part number you would seek is WB36X10003 this is not cheap for a bulb, you maybe able to get a replacement from a local lighting center near you. its a 40 watt, 130V bulb
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Overhead microwave light won't turn off after replacing bulbs
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for only $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
1helpful
What size bulb does the JVM1871SK04 GE XL 1800 use?
The bulbs are 40 watt incandescent.
The GE part number is WB36x10003
1helpful
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
2helpful
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Circuit Board
Okay, sure.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
Sharp carousel non functional overhead light
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
William E. Miller
[email protected]
1helpful
Replace Extrerior Bulb
Your owner's manual can be downloaded here. Page 31 covers the procedure:
plug.
2 Remove the screw at the
front of the light cover
and lower the cover.
and type bulb.
4 Raise the light shield
to the oven.
bulb with a 40-watt
incandescent bulb
My tips if the bulb sticks in the socket:
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Top GE Microwave Ovens Experts
vince
Paul Bade
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
