I have set different colors to represent each of the companies I am the accountant for and I am having trouble with the colors on the screen changing all the time. Example: This morning I used orange and that color is green this afternoon. Any ideas?
Thanks!
Bonnie
Now that is one wild post.?
NO PC told
no OS told
no what app shows wrong colors
what does wrong mean? we can not see it.
what are you doing, with the PC, and application of some kind or just windows screens wrong.
is this a artist point of view , for Publishing in perfect tints?
does VA2026w fail on 2nd PC?
old monitors (trashy) have CCFL back lamps
and go yellow tinged for white, and yellow added to other colors are trash. too.
let me C 14 carbon date this MON.
2007 made and is CCFL lamps and all are bad now
or yellow dog tinged or changes hot../cold or random.
time to get a real monitor called LED 2010 or newer.
2007 are junk,
the CCFL will go dead next. all do.
here is what mine looks like, then,.... long ago.
just like this.
https://www.pcdied.com/monitors_and_screens/yellow-ccfl.JPG
pure trash monitors, all brands that year or older
2010 is the cusp year CCFL > LED
starting with big screens to small.
so 2011 is best year up;.
2010 some are some not.
2007 is junk,
SOURCE: Dual-Monitor Color Difference
The solution to this one is simple. Goto to the monitor that does not match and match it through the front panel settings. Also I would check to see if both are set exactly alike in the windows hardware settings.
SOURCE: lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
SOURCE: the colors on my monitor are faded/bright always changing.
Right click on your desktop (not an icon but a blank space), click "personalize", click on the tab on the far right(settings), click the drop-down menu on the left side above the colored banner, make sure it is set to the most colors(usually 32). If you need a walkthrough for Vista I can provide that as well.
