Aiwa XD-DV370 DVD Player Logo
A
Anonymous Posted on Sep 14, 2013
Gets frozen - Aiwa XD-DV370 DVD Player
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
FROZEN SCREEN
If your phone gets frozen somewhere and cant return home , simply take out its battery and reinsert it , after that switch on your phone and it will starts working as before. And after doing so check for any virus and intursware or corrupted application that caused the frozen , and fix this. thank you regards amir saleem
Freezing problem
You don't want minimum temperatures if food is getting frozen. The less the temperature is, the colder it will be. If food is getting frozen, increase the temperature. Usually there is a dial in refrigerators, for example, with the numbers 1-7, 1 will be coldest and 7 will be warmest.
Frozen
update its drivers from your computer then remove battery and restart.
6helpful
3answers
All functions are frozen. Had music playing & at same time activated stop watch. At some point it froze on the stop watch display. Cannot power off or get menu...frozen, frozen, frozen!!!!
  • Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds.
  • Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Zune frozen with logo
ahhh, yes, the frozen Zune. Figured it out, hm? Got it working, right? Good...
2helpful
2answers
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
john h
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
