Question about Star Kitchen Appliances - Others
I njee wring diagram for star fryer 615 fd...thermo coupler instalation
Posted by david terry on
Angel Joseph Jr.
  • Star Expert
  • 684 Answers
Hi there. Visit www.starwebconnect.com/Manuals.aspx then click the fryer tab wherein yo will find the wiring diagram you need.
Regards.
Posted on Nov 22, 2013
Needs wiring diagram without the Relay HI-Limit Thermo
You can download Owner's Manual which contains Wiring Diagram at http://www.wellsbloomfield.com
Regards.
Jun 18, 2011 | Wells F-49 21148 Deep Fryer
My superior deep fryer turns off including the pilot when it reaches about 300 or 350 degrese. this problem started after i cleaned it. iits a comercial gas fryer in my restaurant
HEY, MY NAME IS KEVIN AND IM IN THE RESTAURANT BUSINESS AS WELL. IVE HAD THAT SAME PROBLEM,THE FIX IS TO REPLACE THE THERMO COUPLER. PART COST ABOUT 40.00 - 50.00 BUCKS DEPENDING WHERE U FIND IT. ANY QUESTIONS UFEEL FREE TO EMAIL ME. [email protected]
Nov 30, 2009 | Philips HD6153 Deep Fryer
I have a Pitco 35C+S fryer that goes out. When I relight the pilot, turn the gas on. the burners light and blow flame hard for a second or two and then die down to normal. It will relight with the...
With the thermostat on the burners are still getting gas. that's normal. If it lights with the thermostat off you do have a severe problem. (bad gas valve/Tstat). The pilot does occasionaly go out on all no electronic ignition items is normal. Follow the remommended steps for relighting and if it lights fine your ok.
Aug 15, 2009 | Pitco Frialator 35CS Deep Fryer
Need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
May 07, 2009 | Star 530TD Deep Fryer
Burner will not light, but pilot is on
Sounds like you need a new thermo coupler. this is first and foremost.
Can you light the burners by hand? and do they burn hot and clean that will let you know if you have clear intake lines for the gas.
There is a small chance the gas valve is having a problem,not at the burner control but the vavle the thermo coupler is connected to. or worse case scenario moisture in the gas line.
Feb 02, 2009 | Imperial IFS40 Deep Fryer
Pilot ligt wont stay light
My suggestions,
take the electrical wiring off the terminals of the gas valve one at a time, and clean the contacts with a food grade electronics contact cleaner and degreaser. Make sure all wiring is tight, not loose fitting, and clean. The thermo coupler, or sometimes used thermopile (multiple thermocouples in one) generates a small amount of electrical current when heated. The oil residue on a gas valve's electrical contacts SHORTS OUT THE MINUTE CURRENT GENERATED not giving enough current to hold the valve open.
The next thing, how high is your pilot set? If the flame is not striking the thermo pile properly, if its not directally in the flame, it will not generate enough current to hold the gas valve open. Sometimes a dirty thermo pile just cleaned up with sandpaper will work again (accumulated material acts as an insulator)
If you have access to a very high end electrical meter that is capable of measurung MICRO AMPS (very few) then you should check the actual current ouput of the themo pile.
Another thing, the gas valve solonoid MAY BE DEFECTIVE! IF YOUR THERMO PILE is of the screw in type vrs screwed on type, remove the gas valve end, degrease the inside and also that of the thermo pile surfaces, then use the CLEAN errasser of a pencil to clean both the inside of the gas valve connection, and also that of the thermo pile contacts. NO ERRASSER RESIDUE CAN BE LEFT ON EITHER SURFACE! Do not touch these contact surfaces with your hands because even the resistance of the body oil on these surfaces can mean the differance between it working or not!
The thermo pile or a thermo couple generates a minute amount of current that holds the gas valve on.
PS: and that didn't even cost you a dime, I'm off to an emergewncy service call to fix yet another McDonalds deeping fryer (don't call them beeping fryers cause they beep either!!!)
Nov 24, 2008 | Pitco Frialator SG14 Deep Fryer
Pilot light will not stay lit
my pilot is lighting but my deep fryer wont light
Sep 06, 2006 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
Top Star Kitchen Appliances - Others Experts
Bill Boyd
Steve Pack
Steve Pack
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
