SOURCE: I have the below listed Spa pump & heater . No
Thank you for posting your question here on Fixya.com.
First, test to see if power is getting to the element lead posts. If so, your element is bad and will need to be replaced. If not you will need to determine if a limit switch is tripped or bad, if the pressure switch is closing, and if the inline fuse has blown. Any one or combination of those failures will cause the heater to remain off.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: Does anyone know the equivalent relay switch?
Good Day.
www.gohottubs.com have parts for you.
Thank you
