At camping stores you can find silicone based waterproofing spray. Just spray all of the seems according to the directions. In the mean time, if you have a tarp or floor saver under the tent it could go on top, tied down with guy lines if it is windy.
Oh, and be aware that even with waterproof tents, the water can sneak through if anything is touching the wet fabric. The waterproof fabrics hold onto water and lead it down, but the fabric itself is permeable, so keep bags and stuff away from the walls.
the operating system software of your unit has been affected, that's why its malfunctioning. You need to install the firmware update for your device and by so doing, it will reinstall the bad or corrupt operating system files that has been affected.
Visit the below tom-tom link and download the appropriate firmware for your device.
I had the same problem after a rainstorm. Although the unit is supposed to be waterproof, it was not. Garmin replaced the unit when the mist did not clear after a few weeks, and the unit never worked after that.
Had the same problem and no target. Wait after it says touch the center of the target for at least 5 minutes maybe longer and suddenly it will beep and appear. After touching each of the 5 targets as they move from corner to corner and then center the stylus and touch screen once again worked.
If it's under warranty by all means pursue a fix. You might have to send it to a warranty center instead of working with your local dealer.
"Water proof" and "water resistant" are very different. About 20 years ago all watch companies stopped promising waterproof and started using the term water resistant. It gives them wiggle room in the guarantee, unfortunately. I believe T-Touch is supposed to be water resistant to only a few meters.
