Acer Iconia Tab A200-10g16u XE.H8QPN.001 Tablet - Android 3.2 Honeycom Logo
Question about Acer Iconia Tab A200-10g16u XE.H8QPN.001 Tablet - Android 3.2 Honeycom
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Posted by Manuel R Barraza on
Aleksandar Nikodinovski
    New Friend:
    Problem Solver:
  • 8 Answers
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
Posted on Oct 14, 2013
Hi i have an acer iconia tablet ive forgotten my password to unlock the screen how can i resolve this
You would need to do a factory data reset. If you have data backed up, you will be able to retrieve it.
Power off the tablet. Press and hold the Volume Up and the Power button.
SD Image Update Mode
wipe data/factory reset.
Yes - delete all user data.
Reboot system now.
Your tablet will reboot without password
Can I install split-screen on my Acer iconia 1a810 tablet/
I don't think it has split screen capability.
After pressing the reset button on my acer a200 iconia tablet it freezes on start up with only "iconic tab" showing on a black screen, what do I need to do to to restore my tablet to working order
Since you tried to reset the tablet, you can try doing the hard reset. Just to let you know, performing hard reset deletes the data from your tablet.
Iconia Tab A200 How to Perfom Hard Reset
Please let me know if it helps.
8.1 tablet. How do I replace cracked screen?
Amazon.com: Acer Iconia Tab W3-810 8.1" Touch Screen ...
www.amazon.com > ... > Chargers & Adapters
Amazon.com, Inc.Amazon.com: Acer Iconia Tab W3-810 8.1" Touch Screen Digitizer Panel Repair Partreplace: Computers & Accessories.
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
1helpful
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2answers
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Top Acer Tablets & eReaders Experts
Marvin
Marvin
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
