SOURCE: no display
Try Unplugging the monitor and plugging back in again,,,you dont have to shut the PC down to do this,,,if it starts backup,,,then good... if it doesnt,,then you need another Monitor.
An LCD monitor is better for your eyes anyway.
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
SOURCE: vp2000s:Solid green LED with black screen
Please read below before DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: my dell TFT monitor picks power, the power led is ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement bd: www.lcdrepair.us
The cable if VGA is usually a "D" shaped connector, typically all you have to do is align the "D"' connectors so they match up and you should be able to insert the cable and screw it on.
This is what it looks like ....
Thumbs up if this helped you PLEASE!!!!
