SOURCE: reddy r200b keroseen heater will not ignite
CAD flame sensor is bad, also check your air inlet line for the fuel mix, could be cracked.
SOURCE: Radiators not getting up to temperature
depending on the piping configuration; Series loop or mono-flow, you might need bleed the system. If its a mono-flow you would have bleeders on the radiators. Bleed them only till you you have water coming from the bleeders. If its a series loop, you need to bleed them from the area of the circulator by the boiler. There is a urge system you need to use and see if you can get the information on how to do that. I would think that somene here as written a tip on how to purge a series loop hydronic system. Also check to see that you have somewhere in the 12-15 PSI on your system pressure.
SOURCE: I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
SOURCE: Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Testimonial: "Thanks for your advice. I'll look into the Worcester, but I think it might be more than we can afford!! "
