Question about Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers
Moser max 45 won't cut - Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers
Posted by john mcfarlane on
Ross Keen
  • Andis Master
  • 1,365 Answers
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Posted on Nov 07, 2013
My Wahl KM2 worked great the last time I used it which was about a week ago. Now it won't turn on. I checked the outlet and that is good. I tried to plug the KM2 into another outlet and still won't turn...
Ok check the fuse if that's ok and you have a multi-meter check you have power at the circuit board if this is all correct it may just be a faulty switch which isn't a great expense. All parts are the same for the Moser Max 45 and can be viewed below.
http://www.angliaclipperservices.com/Clipper_Parts
Apr 28, 2014 | Wahl KM2 Professional 2-Speed Pet Clipper
Moser baer ivo 515i
exchange battery, battery is out of order
Mar 11, 2014 | Computers & Internet
Moser baer ivo 515i
Replace the battery.
Wahl switchblade won't turn on
Moser Switchblade, check you have current running into the clipper I Suspect in this case maybe Not and therefor a faulty powercable which can be fairly costly
http://www.angliaclipperservices.com/Clipper_Parts/Wahl_Moser/Switchblade
or if you are not conversant with a soldering iron
http://www.angliaclipperservices.com/Repairs_Servicing
Apr 14, 2013 | Wahl Switchblade Professional Power...
Xerox 4150 hard disk problem
First off you can only use a hard drive intended for the copier. Also when you put in the new one you will need the firmware fro the copier. THis has to come from Xerox. If you ordered the HHD from them it may already have it on them.
Nov 05, 2012 | Xerox 4150/XF WorkCentre Multifunction,...
A/C cuts out if fan on max. speed.2000 Mazda MPV fan very slow in 1,2,3 but powerful in 4. However a/c works in 1,2,3 but with fan on 4 it cuts out and won't restart. Obviously the fan resistor
sounds like a fault with the switch unit for the fan ,to know for sure i would need the offending vehicle in front of me take the switch out and have a play ,also of course threaten it with the lump hammer but all joking apart its difficult to diagnose without a play to determine exactly what the problem is
Aug 20, 2012 | 2000 Mazda MPV
2003 taurus recently had rough idle and then cut out expecially after 3-4 short trips in a row and then would not start until it had set for 45 min to 1 hr. Now turns over but won't start. P0191...
then it cuts when hot ?
when cold start is it take some time to run from clod ? if yes then injectors nozzles if not then it is the (coil) well cut off when engine is hot
May 31, 2011 | Ford Taurus Cars & Trucks
Moser bear pen drive
i purchased a 2GB moser bear pen drive. neither it open not shows any type of indication.
Nov 07, 2007 | Electronics - Others
Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers Logo
226 people viewed this question
Top Andis Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
