Question about Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White)
How do I access the drain hole? - Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White)
Posted by ashley pike on
How do i reach the freezer drain hole in a frigidaire refrigerator model #FRT18L4J*?
Hey friend, thanks for your post!
I see you want to access the drain hole on your Frigidaire refrigerator. There is not a direct way to access your drain hole. What exactly are you trying to do with the drain hole? If you can provide me some more information to your issue I might be able to assist you further. I look forward to helping. -Matt
Sep 09, 2014 | Frigidaire Refrigerators
Water in bottom of fridge
The drain tube in any refrigerator is located right below the tray inside the evaporation compartment. A tray below the coils is made so that it funnels out the water. A hole is in the lowest portion of the tray. Junk gets into the tray and blocks the water from draining and so it backs up and flows down to bottom of the frig.
To fix the problem ya gotta remove the service panel and unblock the drain. If ice is blocking the hole you can sometimes run a copper wire down in the hole attached to the defrost heater which is a neat trick. If you would love a service manual I have numerous oneswhich are easy to access at: appliancejunkgoogledrive.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2013 | Refrigerators
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
X5 sunroof drain clogged
You use low pressure air.
May 23, 2012 | 2003 BMW X5
I suspect drain hole clogged. How do I remove the front to access and to clean the coils?
Actually, you will need to remove the back panel of the unit (there are 6-screws) to access the coils.
As far as the drain hole being clogged ... Use an 28" long plastic Zip Tie, sized to fit into the drain hole. If you don't have a Zip Tie, use something similar, bur NO wire coat hangers. Push the Zip Tie into the drain hole and carefully work it in. You will reach a bend in the tubing, but you will have to gingerly work past this bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out, while rotating it. This will dislodge the clog. As you reach the end of the Zip Tie coming out, be prepared for some water to follow.
Hope this helped you solve both problems.
May 26, 2011 | Kenmore 54351 Dehumidifier
Liking water front door
You need to remove the panel inside the freezer compartment to access the evaporator rain line. Once accessed,you will see a drain hole. That drain has a hose leading to a pan in the back of the refrigerator; this drain is plugged an causing water from defrosting ice to drain to the pan in the back of the refrigerator. You need to unstopped that drain hose with compressed air and not chemical.
If you have any probem removed the panel inside the freezer, removed the cardboard panel to access the drain hose. Grab the hose and blow compressed air into it. Please note that you will be blowing back into the freezer compartment, and some cleaning will be necessary. The drain hole will then be opened.
Dec 16, 2010 | Hotpoint HSS25GFP Side by Side...
Water collecting under produce bin which has to be collected every couple of days.Amana model # TX21VE 7.74 amps
Your drain is clogged. Every time it defrosts the water from the defrost should drain out to a catch basin under the ice box. That drain is clogged. You need to access the drain and clear it.
AMANA BOTTOM MOUNT SERVICE MANUAL
2 megs printable version
Helpful?
Sep 30, 2010 | Amana Refrigerators
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water won't drain, door locked. can't open access panel
there is a small hole in round acess door, use a pointed tool or instrument of improvision to stick into hole, turn whole access door. once opened(removed) you will see a manual drain . turn the large cap inside cc wise.have plenty of towels ready.once water drains make sure it is clean inside (of lint,or any other foreign objects. reassemble and se if it works.
Aug 01, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White) Logo
198 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Colin Stickland
Colin Stickland
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
