SOURCE: No rear brake light / turn signals on 2001 Chevy Cavalier
The problem is the turn signal/headlight/hazard switch assembly on the steering column which the brake light wiring runs through. The part is easy to change and cost about $50 at most parts stores
SOURCE: Right turn or brake light not working
Questions? Do any of your brake lights work? Including Center Stop? Do your parking/taillights lights work? All your bulbs are multi-filiment bulbs that work through mulitple sources. Knowing which bulbs are doing what under all conditions might help narrow down the problem. Meanwhile, check for continuity between, stoplight switch and multifuntion switch (white wire). Also, check DrkBlue/White from MFSw. to Boby Control module. BE SURE to use a low inpedance tester to protect your modules. The DrkBl/Wh wire is your rigth side input. I may be a good idea while testing these wires to wiggle them to look for intermitent shorts.
SOURCE: Tail lights don't work on 1998 Chevy Silverado.
check the wiring from the tailights back to the fuse panel, it sounds like an open connection. if i recall correctly check under the dash on the drivers side near the fuse panel for a bunch of wires in a bundle and look carefully for a wire or two that are cut/shorted/or seperated, you can also check under the drivers side kick panel by the hood release.
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights
not working?
http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing?
http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
