SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
SOURCE: I need the replacement (plastic)
I always mention 1800Parts.com because they get us everything. Check their website or call them and see if they can get you the part. Tell them we sent you and they might give you a discount.
SOURCE: my chef chopper bowl has a crack in it would like
Go to http://www.appliancepartspros.com/ and search by model number. They have everything you need at good prices. They have saved me lots of $$$ on various replacement parts as they are usually the cheapest because of tax and shipping. Hope this helps!
Disassembled chopper, notice there is an internal white pulse button that is pushed in when working bowl is assembled and pulse is pressed. There is a white part stripped in the handle of the working bowl that has a small spring. The spring is suppose to push the white part in the handle when the pulse button is pressed. The white strip in the handle of the chopper was not being pushed out by the spring, it is worn out. So after reassembling the unit, a small thin knife was inserted in the handle to push the white strip forward. The chopper worked fine but will need to have the white strip manually moved forward with each use.
