Question about Pride Jazzy Select 6 Indoor Power Wheelchair
My jazzy select makes a clicking noise as i am riding in it. what causes this?
Posted by Myra Hattersley on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Low battery will cause this have your batterys checked for a shorted cell
Posted on Jan 20, 2014
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
What is the torque specification for the drive shaft to wheel hub nut on my mom's Jazzy?
Hi this happens with a lot of scooters u could try some LOCKTIGHT unsrew the nuts put the locktight on & tighten them up I use a 2 foot socket bar to tighten them ....good luck
Dec 15, 2015 | Pride Jazzy Select Gt Scooter
Have a jazzy elite bought it for $ 200 new has been making a pronounced clicking noise while in operation
hi tighten the centre wheel nuts if they r loose they will make a clicking noise hope this helps
Dec 12, 2015 | Pride Mobility Jazzy Select Elite - Jazzy...
Noise in gear box troubleshoot jazzy scooter
Gearbox noise is a good indicator that the gearbox is getting ready to fail. The best solution is to replace the motor and gearbox. If you don't have insurance they can be rebuilt for some cost savings.
Feb 23, 2014 | Pride Jazzy Select 6 Indoor Power...
Jazzy select is swaying side to side when going forward like it has too much play in the joystick
Check your tire inflation and treads to make sure they can grip the floor/ground without slipping. Make sure that any keystock/keylock needed is installed on the axle, sometimes they slip out. Are your batteries fully charged and in good condition? Are you over the weight limit for the power chair?
Is there any noise or vibration coming from the power chair as you operate it? A grinding sound may indicate bad bearings in the caster wheels and cause problems in steering. A chirping sound may indicate a bad motor, they may be losing power and are not able to move the power chair evenly.
If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 28, 2010 | Pride Jazzy Select 6 Indoor Power...
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Sep 30, 2009 | Select Products Power Chair Pride Jazzy...
My Jazzy wheelchair shuts down often when I was riding it, I thought it was the battery problems, I replaced t he batteries, and it still do the samething to me, what can be the problem?
check the inline fuse on the pos side of the battery it is encased in shrinkwrap,if it is loose the chair will act dead and everything will test good.I had this problem on my jazzy select14,and just happen to find it out by chance. an easy way to see if it is the fuse is to take it out and see if it works,without it.anyway good luck! and happy riding!!!
J Olaf
Jul 31, 2009 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
212 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
