Question about Golden Technologies Alante' Power Chair
Something got wet at the lower part of chair a few days ago, now control flashes 2 yellow lights and not working. how do I fix it?
Posted by Patricia Brown on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Says that is a battery fault may need charging
Posted on Jan 20, 2014
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My power chair got wet in rain and won't start and lights olny flashing and what is meaning of vsi? how to ftx problem..please help!
VSI is the controller under the joy stick. Water will ruin the electronic circuits . The controller is expensive new. You can find rebuilt ones cheaper or can have yours rebuilt. Check your local mobility service shop or on line repair facilities.
Oct 12, 2012 | Pride Go Chair Travel Power Chair
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
on my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Jun 18, 2010 | Invacare Pronto M51 Power Wheelchair
Chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
The top row of lights are flashing but no other lights are on. I got it wet the other day but it is dry inside and out. Is there a reset on the mpv 5
How many lights are flashing? You may want to have the power chair sit for several days to make sure the electrionics inside the controller are fully dry. You can try to reset the brakes by lowering and then raising the brake levers located on front of the footrest. If this does not work, the controller is probably fried and will need to be replaced; $1159.00 plus labor.
Sep 28, 2009 | NRS Hoveround MPV 5 - Used Power...
Golden Technologies Alante' Power Chair Logo
111 people viewed this question
Top Golden Technologies Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
