Check for reset in back of unit, otherwise could be burnt off wire inside unit to power cord, also check out good known working electrical outlet first.
I bought Mr. coffee grinder it broke , stopped working on the 3rd use... just 2 months. i called to see if any warranty, thank God i got a replacement with a different model. And now on my 4th time using the new one, it stopped working just like the first one. I'm so sad and frustrated, No one grinds coffee all the time but Mr coffee grinder would not work the only time you need it
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
