Question about Zanussi WJD1257W Front Load Washer
SOURCE: Zanussi WJD1257W Washer/Dryer
if computer is broken that is your timer dial not worth fixing sometimes as much as a new washer but it could be your interlock you can test this by closing door set machine to a programme hit the front of your washer to the right of the door as you look at it if not take lid of make sure power is off look down inside the front of your machine were your door seal is attached to the outer drum were u hit the washer on the inside will be your interlock switch replace that before paying out for a timer m8 more than likely that is the problem
Posted on Aug 13, 2007
SOURCE: I have a zanussi zwd12270w
it sounds like you may have a problem with the door interlock !
Has your machine displayed any error codes ?
regards
Ian
Posted on Apr 17, 2011
