My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears. 2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method. Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar. 2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Power ON the television (Use remote Commander) 1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV) 2. Press the "home" button on the remote. 3. Select "settings" 4. Select "set up" 5. Scroll down to "factory setting" and restore them. 6. When it asks home or shop display select "home".
I have a Maxim 15" Portable LCD TV with built in DVB-T Tuner.
It has worked well for 2 years.
Now when you switch it on set to DTV
Starts to reload the channels
Once it has found 90 channels it moves to Add and will not add any.
There are no stored channels from the built in freeview.
However we still have the normal 4 on ATV.
Any advice.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
