Panasonic Lumix DMC-LZ5 Digital Camera Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shutter When I turn on the camera everything is fine but the shutter wont open. Instead i have to use my fingers to keep the shutter open just to take a picture. I dont know how this happend. I use the camera for an hour and everything is fine then I leave it in its case for like 10 minutes and when i turn it back on the shutter wouldnt open! Please help! :(
  • critter2 Nov 09, 2007
    Everything works on my camera but the lens cover, which does not open automatically when the lens extends. I can gently push it open, but the springs close it instantly. Camera was working fine one day and then this happened when I took it out of the pouch. It hasn't been overused or dropped, and turning it on and off repeatedly or removing and reinserting the battery don't change the situation. Any ideas on how to fix?
  • daveisdavid Jan 21, 2008
    Hi stiny1130 and critter2,
    I also encounter the same problem with the shutter closed at times.
    However, how do you use your finger to open the shutter since there is a glass that preven you to do so?
    I notice that whenever I go to cold countries, this problem occurs. I'm wondering whether could it be that this model cannot stand the coldness thus the shutter malfunction.
cwradio73
Level 3:
  • Master 1,162 Answers
  • Posted on Aug 04, 2009
cwradio73
Master
Level 3:
Answers
1162
Questions
0
Helped
363496
Points
3460
You mean the lens protector doors, not the camera shutter. This seems to be a problem on this camera. Aparently you bumped it against something or dropped it. The only way I know of to fix this is to take it apart and set the arm of the spring again into the side as it should be. You cant do it with out takeing it apart.
Pictures are blurry
The most common causes of blurry pictures are not holding the camera still and correctly pressing the shutter release button or using a slow shutter speed.
Let\'s talk about properly holding your camera first. Always hold your camera with both hands. With an SLR such as yours, grip the left side of the camera with your left hand and cradle the camera from underneath with your right hand using you thumb and index fingers to zoom. Hold your arms so that both elbows rest on either side of your chest and brace the top of the camera against your forehead. This forms a rigid triangle of support.
The second thing you must do is properly press the shutter release button. Do not poke the button because you will jerk the camera and that can cause blur. Instead, start to press the button gradually increasing the pressure until the shutter trips. It should trip almost by surprise. This is very similar to how a marksman pulls the trigger on a gun.
Assuming that you are holding your camera correctly, not "punching" your shutter button and your camera is not defective, here are two easy ways to solve your problem. First, you could use the manual exposure mode and keep your shutter speed at 1/500 second or faster. Second, go to the "S" shutter priority mode and set the shutter speed above 1/500 second. Your camera will automatically adjust the f-stop (lens diaphragm opening) and "film speed" for proper exposure. Please let me know if this resolved your problem.
When we take picture it show picture blurry
Camera screen will not light up
The LCD screen maybe faulty.
Take your camera to an Olympus camera repairer for repair.
I have exactly the same problem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
4helpful
2answers
My camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
Shutter issue
I experienced the same problem and took the camera in for repair - I was told the problem was with the motor on the zoom drive which had to be replaced. The shutter cover has worked fine ever since. Repair cost was about $150
1helpful
Samsung L83t will not turn on! Fully charged but wont turn on.
mine was the same.i noticed the lens shutter was not opening so i opened it with my fingers and its fine now . i hope this solves it
Apr 18, 2008 • Cameras
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
