Question about HP LaserJet 4730 MFP Printer
Reset nvram hp CM4730 mfp - HP LaserJet 4730 MFP Printer
3 Related Answers
Anonymous
  • 16 Answers
SOURCE: Having problem with out going
you need to set your fax settings differently. Print out a MENU MAP (menu,information,config pages, menumap) and find these settings....ECM to ON JBIG to OFF V34 to OFF and MAX BAUDRATE to 14.4. After those are set you need to upgrade to latest firmware
Posted on May 14, 2010
guilopmar
  • 304 Answers
SOURCE: How can I perform an
NVRAM initialization
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Posted on Aug 02, 2011
vinay229229
Vinaya Kumar Kuchipudi
  • 1121 Answers
SOURCE: Hp Color Laserjet CM4730 MFP
Lift adf unit, observe two glasses ment for scanning,in that small glass needs to be cleaned, clean the glass with cleaner to avoid this issue.
Posted on Sep 24, 2011
Initializing scanner please wait
Reset the NVRAM should fix the problem. Get the NVRAM reset procedures from HP support site or Google them. Regards, Mike
Apr 03, 2014 | HP LaserJet 4730 MFP Printer
I had received mms from http://mms.live.vodafone.in my message key is MSG.67.4073 how can i open on my net..??
Dear kunal89rkl
Hope you have 3G enabled in your mobile, if so you could be able to open the mms.
Feb 04, 2012 | HP COLOUR LASERJET CM4730 F MFP Printer
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
How can I perform an NVRAM initialization with my HP CM1015 MFP
default settings
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
My HP cm4730 won't make make copies, It still prints fine
have a professional take a look at it to see whether there is any internal damage that disallow for copies to be made.
Jun 11, 2010 | HP LaserJet 4730 MFP Printer
Magenta pin stripe on HP-CM4730 crossing the full length of page.
Replace the magenta cartridge or replace the plastic clear guide on underside of document feeder if happening using the document feeder
Jan 13, 2010 | HP LaserJet 4730 MFP Printer
Display frozen on "initiating scanner", start button illuminated
Turn off, hold down 6 button and keep holding while turn on. Wait for the three lights to stay on then hit the 3 button to scroll down to COLD RESEt and touch 6. It should restart itself and possible fix it.
Mar 09, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
Having problem with out going faxes. Customers not receiving. HP CM4730 MFP
Jan 29, 2009 | HP Color LaserJet CM4730f MFP -...
HP LaserJet 4730 MFP Printer Logo
571 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
