Question about Xerox WorkCentre 4150 Black and White Copier
Seal tape from toner cartridge tore - Xerox WorkCentre 4150 Black and White Copier
Posted by Cherry Daniel on
bhanu batra
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 86 Answers
Prining invoices to letterhead, your laser printer is an integral part of your company's computer system. The device's ink is stored in one or more toner cartridges that are replaceable - a single black cartridge, if you have a laser printer that only prints black, or three color cartridges along with a black cartridge if the laser printer prints both color and black. The cartridges are available at office supply, retail and warehouse stores. Like inkjet cartridges, toner cartridges contain a strip of sealing tape that keeps the powder ink from spilling out until you are ready to install the cartridge.
Sponsored Link
Computer AMC ServicesOnlinepcshop.in
Laptop-PC Repairs in Delhi NCR. Total PC Solutions. Get Free Quotes
1Remove the toner cartridge from its packaging, if the cartridge is still in its box, and shake the cartridge from side to side to evenly distribute its toner.
2Hold the cartridge away from your body so ink won't spill onto your clothes or shoes. Grab the cartridge's sealing tape on the side of the cartridge and pull the tape firmly away from the cartridge. The sealing tape contains a plastic end piece for grasping it, usually in a different color than the toner cartridge.
3Continue pulling the sealing tape until it is completely out of the cartridge. Place the cartridge close to your printer or on a surface nearby until you are ready to install it. Dispose of the sealing tape in a trashcan or bag; try not to get any toner present on the tape on your hands or clothing.
Posted on Sep 14, 2013
Canon lbp7660cdn
Carol, Did you remove the sealing tape? There should be a small orange tab on the left side of the toner. Its integrated with the toner cartridge and easy to miss. Flip that tab over and pull. It will pull out the protective tape.
Aug 05, 2014 | Canon Imageclass Lbp7660cdn Laser Printer...
Hi- I have an MF8170c. The green "recv'd in memory" indicator is lit and I know there are documents que'ed that are waiting to print. I changed a printer cartridge that was I was being...
Replacing the Toner Cartridges
If printout becomes faint or inconsistent, the reason may be that the lifetime of the toner cartridge has been reached even when a message does not appear. Do not continue to use the toner cartridge when there is a deterioration in the print quality.
The lifetime of toner cartridges for this machine is indicated as follows. The number of pages is based on printing a typical document (with a printing ratio of approximately 5 % and print density set to default).
- Black (EP-87) Toner Cartridge Black): Approx. 5,000 pages for printing paper in size of A4 or Letter.
- Yellow, magenta, cyan (EP-87 Toner Cartridge Yellow, EP-87 Toner Cartridge Magenta, EP-87 Toner Cartridge Cyan): Approx. 4,000 pages of printing paper in size of A4 or Letter.
When [PREPARE NEW* CART] and then [REPLACE* CARTRIDGE] appears in the LCD, replace the toner cartridge of the indicated color with a new toner cartridge.
* Indicates either "C", "M", "Y", or "K"
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite resulting in burns or a fire.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Do not use warm water as this may set the toner permanently, and you may not be able to remove the toner stains.
Use only toner cartridges intended for use with this machine.
Press .
Press or to select [MAINTENANCE], then press .
Press or to select [CHANGE CARTRIDGE], then press .
Press or to select the cartridge to be replaced, then press .
You can select from the following:
-[BLACK]
-[CYAN]
-[MAGENTA]
-[YELLOW]
-[ALL COLORS]
Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
Make sure that the toner cartridge you want to replace is at the position for replacing.
If the spent toner cartridge is not in the replacement position, close the cover, then open it again when the sound of machine stops. Repeat this process until the cartridge you want to replace is in the correct position.
Remove the toner cartridge from the machine.
Hold the grip on the toner cartridge and lift it straight up.
Confirm the color of the label on the toner cartridge holder, then take out a toner cartridge of the same color from the protective bag.
Open the protective bag with scissors, so as not to damage the cartridge.
Keep the protective bag in which the cartridge came in. It may be required when taking out the toner cartridge for machine maintenance.
Be careful not to hold or touch the prohibited portions such as the sensor or electrical contacts. It may result in damage to the machine.
Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
If toner is not distributed evenly, it may result in a deterioration of the print quality. Be sure to carry out this procedure properly.
Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
It may be a little snug, but it will pull off.
Do not touch or hold the developing roller. The image quality may deteriorate if you do. Do not apply shock to the toner cartridge memory or bring it near magnetic waves as this may result in damage to the machine.
Keep the protective cover with which the cartridge from removed. It may be required when taking out the toner cartridge for machine maintenance.
Place the toner cartridge on a flat surface, then pull out the sealing tape (Approx. 45 cm (17.72") in length) while supporting the toner cartridge.
Hold the tab on the sealing tape and pull it straight out.
If the sealing tape is pulled out forcefully or stopped at midpoint, toner may spill. If toner gets into your eyes or mouth, wash it away immediately and consult a physician.
Do not pull the sealing tape diagonally, upwards, or downwards. If the tape is severed, it may become difficult to pull it out completely.
Pull out the sealing tape completely from the toner cartridge. If the sealing tape remains in the toner cartridge, it may result in a deterioration in print quality.
Dispose of the sealing tape according to local regulations.
Hold the grip on the toner cartridge and install it in the machine.
Position the triangular mark on the toner cartridge with the triangular mark on the machine and instlal the toner cartridge.
When the toner cartridge is installed properly, the label on the cartridge and on the toner cartridge holder will be aligned as shown in the figure.
Close the cartridge cover and lower the scanning platform.
The toner cartridge holder will rotate automatically.
Aug 31, 2011 | Canon imageCLASS MF8170C All-In-One Laser...
Toner supply failed, remove seal tape from toner cartridge and reinstall
The cartridge inside the printer that holds the dry toner could be empty.
Or, if you have just replaced the toner cartridge, you forgot to remove a piece of "sealer" tape from the cartridge. Remove the cartridge from the printer. Remove that tape from the cartridge. Re-insert the cartridge. Try again.
May 05, 2011 | Office Equipment & Supplies
How to fill catridge show with images
How to Replace the Toner Cartridge:
Replace the toner cartridge with a new one using the following procedure. When replacing the toner cartridge, clean the fixing unit using the Printer Status Window. For details on cleaning the fixing unit, see "How to clean the fixing unit" in Related Information at the end of this page.
Important: Do not touch the high-voltage contacts (A) inside the top cover, as this may result in damage to the printer.
1. Open the top cover. Holding the top cover by the cutout edge, open the cover until it stops.
2. Raise the toner cartridge in the direction of the arrow (1), then remove it (2).
3. Take a new toner cartridge out of the protective bag. As there is a notch cut near the arrow, you can tear open the bag by hand. However, if you are unable to tear open the bag by hand, use scissors to open the protective bag so as not to damage the toner cartridge.
Important: a. Keep the protective bag for the toner cartridge. It will be required after taking out the toner cartridge for printer maintenance. b. Print quality may deteriorate if you touch or damage the drum inside the drum cartridge. Be sure not to touch or open the drum protective shutter (A). Be careful not to hold or touch sensitive areas that are not specified in this procedure. This may result in damage to the cartridge.
c. Do not expose the toner cartridge to direct sunlight or strong light.
4. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times to evenly distribute the toner inside the cartridge.
Important: a. If the toner is not distributed evenly, this may result in deterioration in print quality. Be sure to perform this step properly. b. Be sure to shake the toner cartridge gently. If you do not shake the cartridge gently, toner may spill out. c. Be careful not to hold or touch sensitive areas such as the electrical contacts (A) or sensor, as this may result in damage to the toner cartridge or printer.
5. Place the toner cartridge on a flat surface, then pull out the sealing tape (approx. 50 cm long) gently while supporting the toner cartridge. Pull out the sealing tape straight in the direction of the arrow.
Important: a. Do not pull the sealing tape diagonally, upwards, or downwards. If the tape is severed, it may become difficult to pull out completely.
b. Pull out the sealing tape completely from the toner cartridge. If any tape remains in the toner cartridge, this may result in poor print quality. c. When pulling out the sealing tape, be careful not to hold the drum protective shutter (A) with your hands.
d. After removing the protective bag, install the toner cartridge in the printer as soon as possible. e. Dispose of the sealing tape according to local regulations.
6. Align the projections on both sides of the toner cartridge with the toner cartridge guide inside the printer, push the toner cartridge completely into the printer (1), and then pull it down toward you (2).
7. Close the top cover.
Nov 30, 2010 | Canon LASER SHOT LBP-2900 Printer
What does it mean when the printer says "prepare new k cart"
It means that the black ink cartridge is going to be used up soon so you would better get a replacement at hand to avoid interruptions.Probably REPLACE K CARTRIDGE will appear sometime later.
To replace cartridge do as follows:
Get a Black (EP-87) Toner Cartridge.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [MAINTENANCE], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [CHANGE CARTRIDGE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the cartridge to be replaced, then press <Set>.
    Select [BLACK]
  5. Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
  6. Make sure that the toner cartridge you want to replace is at the position for replacing.
    Ifthe spent toner cartridge is not in the replacement position, close thecover, then open it again when the sound of machine stops. Repeat thisprocess until the cartridge you want to replace is in the correctposition.
  7. Remove the toner cartridge from the machine.
  8. Confirm the color of the label on the toner cartridge holder,then take out a toner cartridge of the same color from the protectivebag.
    • Keepthe protective bag in which the cartridge came in. It may be requiredwhen taking out the toner cartridge for machine maintenance.
    • Becareful not to hold or touch the prohibited portions such as the sensoror electrical contacts. It may result in damage to the machine.
  9. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
    • Iftoner is not distributed evenly, it may result in a deterioration ofthe print quality. Be sure to carry out this procedure properly.
    • Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
  10. Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
    • Donot touch or hold the developing roller. The image quality maydeteriorate if you do. Do not apply shock to the toner cartridge memoryor bring it near magnetic waves as this may result in damage to themachine.
    • Keepthe protective cover with which the cartridge from removed. It may berequired when taking out the toner cartridge for machine maintenance.
  11. Place the toner cartridge on a flat surface, then pull out thesealing tape (Approx. 45 cm (17.72") in length) while supporting thetoner cartridge.
    Ifthe sealing tape is pulled out forcefully or stopped at midpoint, tonermay spill. If toner gets into your eyes or mouth, wash it awayimmediately and consult a physician.
    • Donot pull the sealing tape diagonally, upwards, or downwards. If thetape is severed, it may become difficult to pull it out completely.
    • Pullout the sealing tape completely from the toner cartridge. If thesealing tape remains in the toner cartridge, it may result in adeterioration in print quality.
    • Dispose of the sealing tape according to local regulations.
  12. Hold the grip on the toner cartridge and install it in the machine.
    Whenthe toner cartridge is installed properly, the label on the cartridgeand on the toner cartridge holder will be aligned as shown in thefigure.
  13. Close the cartridge cover and lower the scanning platform.
Nov 27, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Sharp ARM-455 F202 error code and says check toner cart.
There is any solution for error F2-02 without changing any Toner Cartridge
Jun 05, 2008 | Sharp Office Equipment & Supplies
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
Brother HL-2070N
stars-5-0._v47081849_.gif Masking Tape Gives TN-350 Toner a Second Life, August 25, 2008 By C. MACPHAIL "cmacphail3"drop-down-icon-small-empty-arrow._v13355991_.gif
After the "Toner Life End" message appears, it refuses to printeven one more copy. Offensive...until you show it who's in charge.
Remove the cartridge and find 2 clear plastic port holes, one oneach side. The printer shines a light through these to decide when toshut you off. But it's too sudden and too early.
Cover one or both windows with a small piece of masking tape. I get about 3400 copies per cartridge instead of 2400.
(Reportthis)
Aug 17, 2007 | Brother HL-2040 Laser Printer
Xerox WorkCentre 4150 Black and White Copier Logo
307 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
