Question about HP Photosmart C5180 All-In-One InkJet Printer
Wont recognize cartridge - HP Photosmart C5180 All-In-One InkJet Printer
Posted by MIlton Chapman on
Rod Eslinger
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
In most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the HP02 (or 363 in the UK) cartridge is initially installed into the printer. Click here for more information when using refilled ink cartridges or general printing problems using any HP02 ink cartridge: http://inkjet411.com/?page_id=1372
However, if you also observe an INK SYSTEM FAILURE message then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A.HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
    1.Press * and # keys simultaneously.
    2. "Enter Special Key Combo" will be displayed.
    3.Press 123 to display the 'Support/Service' menu.
    4.At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
    5.Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
    6.Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
    7.Select Ok. The test page prints.
    8.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    B.HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
    Internal Test Print:
    1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
    2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
    Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
    1. Turn ON the printer.
    2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
    3. Release both buttons.
    4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
    5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
    6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
    7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
    8. Select Ok. The test page prints.
    9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    NOTE: Costco USA/Canada, Fry's Electronic's, Microelectronics (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
    http://www.costcoinkjetrefill.com/pricing
    For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
    To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Dec 04, 2013
Recognize ink cartridges
Are the cartridges the same as recommended by OEM? If not, the printer will not recognize it.
Switch off, check if printer still your default. Do a test. If no luck, go to tools and clean and align cartridges. GL
Aug 18, 2013 | Canon Pixma MX360 Printer
I have replaced my ink cartridge on my Epsom TX110 and it wont recognize the new cartridge it thinks its none genuine but its genuine its the Epsom 91N cartridge. i have tried cleaning chip that doesn't...
try this one link below, or else you need to replace printer head assembly.
http://downloadaccess.net/search.php?PID=851f9112-c11b-4e76-ba40-c351bd1419f5&q=free%20download%20epson%20tx110%20resetter%20software
Mar 25, 2010 | Epson Stylus NX400 InkJet Printer
Epson do not recognizing new cartridges
Just posted this answer somewhere else...you probably touched the little green microchip on the cartridge. The oils in your hand prevent the printer from reading the cartridge. Hope this helps, sucks that you may have to buy a new cartridge though!
Aug 05, 2009 | Epson Stylus 1400 InkJet Photo Printer
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
Wont recognize pg40 refilled cartrige
you will have to buy a new origenal cartridge.the cartridge have a pcb at the back that is damage.
May 12, 2009 | Canon FAX-JX200
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Refilled cartridge dell 924 wont recognize
can someone direct me on how to put ink in my printer
Feb 03, 2009 | Dell 924 All-in-One InkJet Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
HP Photosmart C5180 All-In-One InkJet Printer Logo
73 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
