SOURCE: Bad Smell
you might ry removeing hte rear panel of freezer. gain access to the evapotator area, thats where the fan thatcirculates air is as well, if the smells stillback there washing the inside wont do anything. once fully exposed i would saturate area with an odor nuetralizer . I use odo-ban. and be sure to pour asolution of baking soda and water downt the drain assy (under the evaperator) that will allow the baking soda to reamin in the lower drip tray long after teh eater evaporates. once refrig gets vcold again the smells generrally disapate anyway
SOURCE: ge profile side by side model tpx2 4pryfbb serial number ls-2858840
I am having the same problem any suggestions........
SOURCE: My fridge and freezer smell
SOURCE: water leaking from freezer forms
Hello and Welcome to FixYa!
Well, it seems like the drain pipe or the drain channel is clogged, and the defrost water from the evaporator coils is dripping through the quoted regions, down to the base. Try checking the drain hose/ channel and remove the clogging if any (Blow some moderate temperature air through the channel and check/ remove any permanent clogging If any). Feel free to ask the details, or any question relevant to the trouble..
Concerned.
Clean up the living area where the gnats are hanging around. This is usually the kitchen .Take away all garbage, clean the sink disposal, and throw away any food residue.
Spray the counters with a cleaner that contains bleach to discourage gnats. Dry off the counters with paper towels.
Pour a cup of ammonia down your sink drains and disposal to coat the inside. Gnats inside the drains will quickly die.
Mix together equal parts apple cider vinegar and dish detergent.
Pour the mixture into small dishes or cups and set them out in the areas where gnats congregate. The gnats will be attracted to the sweetness of the vinegar but will get caught and die in the dish soap.
Keep trash cans covered at all times, and empty them every night.
Leave your compost buckets outside. Gnats love vegetables and fruits.
Avoid over watering your plants. Soggy soil attracts gnats
