Question about Olympus Vg110 Vg-110 Red Digital Camera 16gb Kit
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning it on, the screen shows, WRITE PROTECT Second, will reformatting the micro sd flash drives means that all our pictures will be deleted?
Posted by LJ Lopez on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
Posted on Sep 13, 2013
3 Related Answers
Anonymous
SOURCE: Olympus 2G xd M card with pictures - error message "clean card" or format
Just had the same issue today. The Olympus Helpdesk told me that the fact I had printed one of the picture from the Xd card in directly inserting the card in the printer slot for Xd created the problem....
The guy from the Helpdesk strongly recommended to transfer the pictures from the camera to the computer exclusively using the USB cable of the camera.
In the end I have saved all my 505 pictures in using the Smart Recovery from PC Inspector but why the hell this problem only happens with Xd cards?
Posted on Jan 02, 2009
Anonymous
  • 919 Answers
SOURCE: Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Apr 02, 2009
Anonymous
SOURCE: unwrite protect olympus Fe 280
go to set up and reformat. This will fix the problem
John Harlow
Posted on Jun 26, 2009
Memoricard camera inside werite protect swo
The VG-110 uses SD/SDHC cards, which have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 03, 2014 | Olympus Vg-110 12mp Digital Camera Silver...
Does reformatting the micro sd flash drive removes all the pictres saved in it?
Yes. Formatting the card is the best way to clear the card for further use, AFTER you transfer all the pictures to your computer.
Sep 13, 2013 | Olympus FE-280 Digital Camera
Olympus D-700 manuel
The Instruction Manual for the Olympus VG-110 / D-700 Digital Camera can be downloaded online here:
http://www.olympusamerica.com/files/oima_cckb/VG-110_D-700_Instruction_Manual_EN.pdf
On page 53 there is a section on Error Messages. The Write Protect message indicates that the memory card write-protect switch is set to the "LOCK" position. You will need to remove your memnory card and move the swith to the 'UNLOCKED' position.
See Pages 12 and 58 for illlustrations.
Jan 08, 2012 | Olympus Cameras
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
Using the HP Drive Key Boot Utility, the first way
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Method 2
Method 3
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd 2 gb card it say that it need to be formated but when i click for it format it say windows cound not complete the format
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you
Sep 19, 2011 | SanDisk 2GB microSD Memory Card
I can not get my pictures on my sd card
Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
Jan 02, 2010 | LG enV3 VX9200 Cell Phone
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
Olympus Vg110 Vg-110 Red Digital Camera 16gb Kit Logo
60 people viewed this question
Top Olympus Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you an Olympus Camera Expert? Answer questions, earn points and help others
