Need to know what the spark plug gap on a bg75 stihl hand held leaf blower
SOURCE: STIHL BG75 LEAF BLOWER ELEC. SYSTEM
The unit uses a magneto system. To test the module remove the black wire from the module then reassemble unit and test for spark ( spinning by hand will not work, you need to use the starter rope to get the needed RPM to create a spark). If you have no spark with the ground wire disconnected the module is bad and needs to be replaced. If you DO have spark with the ground wire disconnected then you have a pinched wire going to ground or a bad stop switch
