Cameras Logo
Robert Austin Posted on Sep 13, 2013
The lens is stuck out from the camera and I get a warning message telling to "turn off the camera and turn on again". I do this but the lens still sticks out and doesn't retract however it does move occasionally about half a centimetre. the digital screen appears black besides the settings i.e. SR Auto. I can still access the menu whilst it is on.
Nitin Chandrachud
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 32 Answers
  • Posted on Sep 13, 2013
Nitin Chandrachud
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
32
Questions
0
Helped
5289
Points
49
It looks like you have a jam lens . . Do not force the lens. You may damage the mechanism. Sending it to the service center is advised . .
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Sep 02, 2008
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Anonymous
  • Posted on Oct 10, 2008
SOURCE: Sony DSC W50 - lens stuck
how do i fix my lens if its stuck? please respond i am in need of assistance..
A
Anonymous
  • Posted on Oct 14, 2008
SOURCE: Access Message
Could not believe it but it worked for me as well. First time I see that a good smack makes it work
Anonymous
  • 1197 Answers
  • Posted on Aug 19, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Anonymous
  • 455 Answers
  • Posted on Apr 01, 2011
SOURCE: turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
2helpful
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
1helpful
Message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
1helpful
Message turn power on and off... Lens stuck as well.
u may as well kill urself. its broken. go get it checked out. i took apart my camera and tried to fix it myself... i shocked the **** out of my hand. best buy or something
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Lens stuck
I just wrote a warning about these "telescoping lens" cameras, You need to get the lens back on track. maybe steady pressure, applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body.
Lens won't close
Hey daisy16,
If this problem only started happening after you dropped your camera there is likely physical damage to the lens, and you need to have it looked at by an authorized service technician. When this camera has a hardware problem it will tell the user to turn it off and back on, but since the physical problem is not actually resolved by doing this you gets the message again.
Sincerely,
Allan
Go Ahead. Use Us.
1helpful
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
2answers
The lens is out
I have the same problem. Camera was dropped and now the lens is stuck and when I turn it on, just tells me to turn of the camera off and then on again. But still stuck. It won't take pictures.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
