Technics SA-EX140 Receiver Logo
Tom Tobias Posted on Sep 13, 2013
Speakers A & B work individually but not simultaneously for full stereo effect
How do i get two sony srsx2 speakers and im trying to get them to run music from my samsung tablet. I got both speakers loaded and working seperately. But they wont work simultaneously. What am i doing...
Check the plug, that plugs into the tablet. Does it have 2 bands, or 3. If it has 2, it can not play stereo. If it has 3 then it can play stereo. As long as you have the setting to stereo.
I get full surround while watching a movie throough the dvd player /blue ray player but cant get surround sound through my normal tv and yes i have a cable box if it matters ,, when i am in stereo mode i...
If you have the users manual for the unit, go to the troubleshooting section or the section that explains how to set individual speaker levels and effects and reset the balance there. It sounds like somebody tried to set things in this way but maybe got a little confused and turned off the wrong selections. There should be a demo program built into the receiver that allows the listener to hear all of the different settings available with the different effects also. Hope this helps.
2helpful
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
2answers
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Sound effects
search in the soundcard software for a place where you can choose stereo 5.1 6.1 ect
go program files and look for the folder creative in there ther is like a file named somethig like creative console its in there the stereo option!
2answers
Sound not working
You can goto the manufacture web site for the speakers and download the latest device drivers and install them on your computer.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
