Under the Table, I only have an X axis and no Y, but I need both. How do I create a table for the Y axis as well?
ok,
I assume that you are attempting to make a scatter plot of some sort. Here's how:
Instead of hitting the [table] button. You should hit the [stat] or [stats] button as I forget which it is. Then hit [enter] which will bring you to a stats list editor of some kind. You will want to enter the data for your x-axis in L1 and the data for your y-axis in L2. Once you have completed your lists, hit the [stat] button again and then click [right] or the right arrow in order to move to the section of calc. from number 4 down it will help create a graph of that type of function. lets say you think it is linear, so you hit [enter] on number 4 and then you will be at the home screen with LinReg already written. You just have to complete the statement and it will do it for you. hit the [2nd] [1] and then the comma button, then [2nd] [2] and [enter]. that will do it for you.
If I am mistaken in my thoughts and you have a graph that you need the points of, type the function into the y= menu or solve a few points and do the above suggestion.
The calculator will not allow you to plug-in values for the y within the table menu.
I hope this helps.
