Motorola TalkAbout T6530R (14 Channels) 2-Way Radio Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roger tone it beeps when the radios transmits to each other how do i turn the roger ton off
  • salmon slut Sep 15, 2007
    motorola t6530
  • Anonymous Mar 18, 2014
    tone is to loud
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Sep 15, 2007
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3094866
Points
19604
Hi, To remove the "Roger Beep", power off the radio. Press on the "+" button, without letting go, power on the radio. Release the button. The "Roger Beep" should be gone by now. To activate, do the same. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
1helpful
I have held the - sign and done this several time and the Roger beep is still sounding what next?
The T6500 is slightly different than many of the other TalkAbout radios where the + (plus) button turns the Roger Beep (aka talk confirmation tone) on or off.
T6500 will turn ON the Roger Beep when turning the radio on with the +, but to shut it OFF you must hold in the - (minus) button while turning the radio on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf You will find the instructions in detail on page 25.
Best regards.
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
Best regards.
How do I silence the beeps on this radio
There are two features which cause the radio to make a tone or beep, before or following a transmission: Talk Confirmation Tones (aka Roger Beep) and Call Tones.
On the T6510 radio you would hold in the + (plus) button while turning the radio on, to turn ON the roger beep. To turn it OFF you would hold in the - (minus) button while turning the radio on.
Call Tones are a little more detailed explanation. You can find directions for both in the user guide on page 25: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Motorola talk about t9500
Check the programming of your frequency, interference code eliminator (code) and Qt filter. Be certain all are identical.
If this does not solve the problem, take the radio back to a basic mode by turning off the special features. (Set the code to zero, the Qt filter to off, the roger beep off, the call tones off) Your radio should work easily without the extras. If the radio doesn't at this point, you have a bad radio.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
Best regards,
I would like to turn off the roger beep on my BellSouth model 229
You need to open the radio and look for the roger beep board. It should be a white wire going to one of the pins on the mic jack. If you interupt that wire the tone will not play. You can either disconnect it, or put a switch on it so you can turn it on and off.
How do i stop my radio from making that bloop bloop noise after i key it
You are either describing a CALL TONE ( The Call Tone obtains others’ attention before you start talking) or the ROGER BEEP (When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.)
To shut off the roger beep, hold in the plus + button while turning the radio on.
The CALL TONE may or may not be a feature of your T5210 radio. I am unable to open the online manual for it to tell for certain. If it does have a CALL TONE feature you would access it by pressing the MENU button until you see a "CA" on the screen along with a number. Using the plus or minus button change the setting to zero, followed by pressing the menu button or the PTT button. The zero setting is equivalent to OFF.
To
1helpful
Hi there i have a strange icon in one of my radios
The icon you are describing is the "roger beep" icon. It would not be the reason your radio is not transmitting. Most likely your programming has been changed. Here is a link to the manual where you can read how to program the radio's frequency and interference eliminator code. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Roger Beep/Talk Confirmation Tone
finished talking.
• To enable Roger Beep/Talk Confirmation Tone, press and hold + (plus button) as you turn
your radio On. Now, when you release the PTT button, your set tone lets your
friends know you’re finished talking and will appear on the display.
• To disable the Talk Confirmation Tone feature, turn your radio Off and then back
On while pressing and holding the + (plus) button.
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
2helpful
4answers
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
