in most of the case as your description, the burned resistor is located on the power supply board, you may do a trouble shutting to replaced the burned components, or replace the whole board.
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Check the IC numbers used in it kit; and distinguish which company kit is used with. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
These sets are quite outdated, there are fewer and fewer repair shops out there for them.
The problem is most likely the power supply (internal), this can be repaired quite simply if you know what to look for. Other problems may or may not include a blown IC, fuse, lamp, or the tube itself.
The cheapest option you've got is to buy a new TV I'm afraid.
