GE WSXH208A Front Load Washer Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE WSSH300G0WW front load washer
Washer will not spin . if run on any wash cycle, will fill for 5 seconds, pause for 45 seconds, fill for 5 seconds, pause for 45...
  • 1 more comment
  • pfil Sep 17, 2007
    thanks boss but it turns out it's the computer module in the back according to troubleshoot codes .
  • marblecat96 Feb 18, 2009
    I have the very same problem...It tumbles but no spin in spin cycle...
  • armychic Feb 21, 2009
    my problem may be the same. It will fill with water but then when it's time to start to begin spinning the wash it will spin only three-quarter of the way and stop. I put it on spin only and it does the same thing. I can hear the motor trying to do something but no full spin or advance to the rest of the cycle. PLEASE HELP.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2005
Points
6
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Sep 16, 2007
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
896501
Points
3465
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2005
Points
WOW - I pulled out ton of lint and probably $5 in change. THANKS
Anonymous
Level 1:
New Friend:
  • Posted on Dec 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2005
Points
Kelwrizzt's solution was spot on. My blockage wasn't caused by lint, but the underwire from one of my girlfriend's bras. That and a few weed eater strings. So I guess we're both at fault. Thanks a ton.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2005
Points
Praise the Lord! I think it worked!! I pulled out a swelled, black, goopy, smelly nursing pad out of the outlet filter along with a quarter, some, screws, several bobby pins, and a Wendy's straw wrapper.
2answers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
1helpful
2answers
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Washer does not spin
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Top GE Washing Machines Experts
Marvin
Marvin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
