Question about Kodak EasyShare SV811 (8858946) Digital Picture Frame
Need a power adapter for my SP113MW picture frame
My sreen for months hs been stuckon screen that says androidsystem recover
Try the simple stuff first ... turn the picture frame off. Then remove the AC power adapter from the a/c socket in the wall. Wait 30 seconds then plug the adapter back into the wall outlet. Turn your picture frame back on and notice any error messages that may get displayed.
Jun 06, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a smartparts picture frame.SP113mw Just loaded new pictures and first pic comes up and freezes, tried re-connecting to computer nothing. Can't use any of the buttons its locked up and can't...
The first (most obvious?) solution is to discard/destroy/disable/discombobulate the SP113MW. For my Mother-in-Law, I just deleted some of her images from built-in flash.
The SP113MW has a 128 mB flash drive that is accessible by USB, per previous suggestions. HOWEVER, the probable reason that your frame freezes on startup is that you have more than 744 images in the "Smartparts Pictures" folder on the built-in flash memory.
The SP113MW has a maximum limit of 744 images for a slideshow rotation, regardless of how much space is on the drive (that includes Built-in flash, USB, SD, or any of the drives). The default drive on startup is the built-in flash, so you may just have to delete some images to get under the 744 limit. FORGET the manufacturer's claim of "2000 images" (because it is technically correct); you can store 2000, but you'll never play a slideshow of 2000 (nor any slideshow if you have that many images). Reduce to 744 (all jpg's) and all will be well.
The other irritating thing about the SP113MW is that it does not allow the slideshow to include all drives: just one drive at a time, and that drive cannot have more than 744 images on it (or the slideshow freezes). That is why your comment about "trash" may not be a bad idea. However, mine Mother-in-Law's still works, so I accepted the limit, and it still sits on her shelf.
Sep 22, 2011 | SmartParts SPX8 Digital Picture Frame
My Smartparts SP15MW picture frame does not start. I have teested the power supply and it give 12v at the output. Only the green LED on the power supply is on. No other lights show.
The power adapters for the SP15MW's burn out very quickly .Take the adapter to Radio Shack to have them test . If it's dead, you need to replace it and then the frame will work.
Feb 23, 2011 | Computers & Internet
My smart parts frame has no power - any suggestions?
Use a "multi-meter" to measure the voltage and amperage output from the power-adapter.
If the values don't match the specifications on the adapter, replace the adapter.
Find a compatible power-adapter (maybe by going back to the store where you bought the SmartParts, taking your frame with you) and trying powering your SmartParts from that adapter.
If it still does not work, then exercise the WARRANTY on the device to get it repaired/replaced.
Jan 11, 2011 | SmartParts (1DPFSP01) Digital Picture...
We've lost part of the AC power adapter for our MemoryVue MV 800 digital frame -- the part that goes from the outlet to the adapter cord that attaches directly to the frame (it's a "two prong"...
I think this is a "figure of eight" power cord, a standard, widely available item. I found a hundred or so right away on Amazon by searching for "figure eight power".
Nov 03, 2010 | Pacific Digital MemoryVue MV-800 Digital...
SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
My picture frames power goes off after about an hour. then if I unplug it and plug it in it works again
It sounds to me that your adapter might be faulty. Your adapter is covered under the same warranty as the frame and can be replaced within 7-10 days.
In order to arrange an exchange for your faulty adapter: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 10, 2009 | Kodak Digital Picture Frame
Frame will not power up or start.
The power adapters for the SP15MW's burn out very quickly so every thoug you have power in the outlet, it is not getting to the frame. Take the adapter to Radio Shack to have them test the voltage. If it's dead, you need to replace it and then the frame will work.
Jun 23, 2009 | SmartParts SP15MW (092566981886) Digital...
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
47 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
