Question about Nikon Coolpix 5000 Digital Camera
Camera won't turn. Is there a way to do a hard reset.
Samsung mhx-w300 won`t turn on
you must press the reset button inside the SD card door. Remove the flash card first. this should allow you to power the camera on.
Feb 04, 2014 | Samsung HMX-W300
How do i hard reset my samsung galaxy player 3.6
my samsung galaxy player wont turn on how can i make it turn on with then a day
Mar 21, 2013 | Samsung Galaxy Player 3.6 8GB* MP3 Player...
Lock code factory reset issues
I'm not sure if I understand your question, but if you have lost your lock code, and want to hard reset, you could try:
Press and hold GREEN + RED + CAMERA when powering up, then
input default 12345 security code.
or maybe
  • To perform a hard reset on a Nokia phone that won't turn on, press simultaneously these 3 buttons:
  • on/off + * + 3
Remember that you will loose all data on phone.
Jun 19, 2012 | Nokia 5230 Cell Phone
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
Hi, I have bought this G1 from Ebay, dont know what is wrong with it. when turn on it vibrates & screen remain blueish black, I tried to Factory reset it. everytime you hard reset it, it gives...
HOpe you did the hard reset by pressing and holding home +power and then alt+w .
Does pressing and holding camera and power gives you the bootloader ( Hboot ) screen . IF yes , try reset from there .
ALso CLick HERE for more details .
Aug 06, 2011 | HTC G1
Camera comes on. screen shows OPTIO AND AT BOTTOM V1.01 THATS ALL- none of the funtions work. camera won't shut offf. have to open battery cover to shut off.
If you can get into the menu system, find "reset" in the set-up menu. If not, remove the card and battery...press every button....leave it alone for 20 minutes...insert the card and then the battery...turn it on.....this is called a "hard reset" and sometimes works.
Jul 17, 2011 | Pentax Optio 50 Digital Camera
Camera will not turn ON. I changed the batteries but still no change.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
Can't unlock phone I forgot my motoblur passcode and my lock code
You need to perform a hard reset on the phone. Follow these directions:
hese steps will wipe all data from the device.
1. Power off the phone. If the phone is frozen and won’t turn off using the Power button, pull the battery out.
2. With the device off, press and hold the Power andCamera buttons.
3. Release the Camera button when prompted to do so.
4. Press and hold the Volume Down button until a yellow exclamation mark appears on the screen.
5. Open the physical keyboard and press ALT + L, then press ALT + W to complete the hard reset of the Cliq.
That should do it! Good luck!!
Aug 10, 2010 | Motorola Mobility CLIQ Cell Phone
HOW DO YOU RESET IT
here"s how...i hope it will help you
1. Power off phone. If it won’t turn off, take the battery out.
2. Press and hold the Power and Camera button at the same time. Release the Camera button when prompted.
3. Press Volume Down key.
4. A yellow triangle will appear. Press on the screen just above the back key.
5. Select option wipedata/factory reset (Alt + W).
The Backflip will then complete the hard reset.
Jun 14, 2010 | Motorola Mobility Backflip Smartphone
Nikon Coolpix 5000 Digital Camera Logo
71 people viewed this question
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
