Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
A
Anonymous Posted on Sep 12, 2013
Is the touch key repairable - Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Touch screen is not working but other function ok
Generally touch are sensitive so it can damage easily when it hits to a hard substance and at the same time we could not repair so to fix this problem the only thing we can do is to change it.There my advise is to visit nearest mobile repairing shop.Good luck thanks for visiting fixya
Touch screen on samsung won't work
U have to take ur phone to the repairer
Cobra 8510 immobiliser touch key not working. I have 2 and one still working correctly so assuming its just the touch key faulty. How can repair, reprogram or replace?
You might need a new receptacle which can be bought online here http://cobracartech.co.uk/home/285-touch-key-receptacle.html
The touch pad works, the right mose key works, but the left mouse key will not work
the problem is with button of left key u have to repair it by opening the plastic body of the touch pad of the laptop there is a switch which has to be replaced if u can do it fine or visit a service technician
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
2answers
GE dryer... the soft touch key pad is not working and the repair man said it will cost an arm and a leg to fix it. Can I repair it my self?
NO. this interface(touch pad), cannot be repaired. The only option is to replace it. The repair tech was correct, unfortunately.
Aug 21, 2009 • Dryers
2answers
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
2answers
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Top Danby Refrigerators Experts
vince
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
