Question about Dell OptiPlex GX110 PC Desktop
Restore factory settings
I forget my bios password
2 Related Answers
Anonymous
  • 204 Answers
SOURCE: my pc needs to be restored to factory settings i
Hi there!
If your computer is using Windows Vista, open this link.
If your computer is using Windows XP, open this link.
Hope this helps.
Posted on May 19, 2011
ahhfrs
  • 10 Answers
SOURCE: B110 Desktop...the bios password has
When I lost my windows password, I like to reset Windows Password with Windows Password Seeker and I think it is excellent and professional! Once the password is removed, there is no need to type any passwords but to leave it blank, and click the user name to instantly log on Windows. http://www.passwordseeker.com/howtouse.html
Posted on May 29, 2012
TOSHIBA RESTORE TO FACTORY SETTINGS WITHOUT DISC OR BIOS PASSWORD
The only way you can manege to restore to factory settings without a cd or a BIOS password is when you remove the hard drive from the pc, slave it to another computer and make a backup of all the data and then format it as an NTFS and then put it back into its computer and then install a new operating system
Sep 09, 2013 | Toshiba Satellite L755-S5158 Laptop
Nokia 7210 i forget my password
If you have forgot the password for a Nokia 7210, you can do a master rest to your mobile. This would restore your phone with default factory settings. you can get the master reset code from www.Classicunlocking.com at affordable cost.
Jun 16, 2012 | Nokia 7210
I want restore code of spice mobil m-4580
i have no remembered Restore Factory settings input password, i want Restore Factory settings input password
Mar 17, 2011 | Cell Phones
Nokia 3110 classic Arabic problem i forget my password for factory restore setting then how can i restore my setting please reply me fast
phones usually have a default restore factory setting code.... "12345"...if you have changed it and you can't remember it...you can take your phone to technician and they will reset all settings including passwords
hope it help..goodluck
Mar 06, 2011 | Cell Phones
BIOS restore
To reset the BIOS to factory settings read the information from this link, disregard the first point as that applies only to bypassing the BIOS password, the other 3 solutions not only will reset the BIOS password but will also bring the BIOS to factory settings.
Feb 10, 2011 | Acer Aspire 1642ZWLMi Notebook
When i power on the laptop ask HDD PASSWORD SIR PLZ HOW CAN I REMOVE SIR
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to Lenovo and many other manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
Jan 21, 2011 | Acer Computers & Internet
My password is correct but the smartware application does not accept it all over a sudden. what can i do to reuse my WD my passport essential 2.0 500gb drive
Hi
According to manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again. Download HDD Unlock Wizard now! 2.8MB only!
It may not be possible to recover the hard drive password or to unlock it; however, it is possible to remove the password together with the data, thus making your hard disk accessible and usable again.
Jan 16, 2011 | Western Digital My Passport Essential SE...
Reset bios IBM ThinkPad R30 2656 PC Notebook
Do a system restore to revert back factory settings holding down F11 when restarting your system. Don't forget to select the backup option to have your documents and files backup for you.
Please rate this....
Mar 20, 2009 | IBM ThinkPad R30 2656 Notebook
Rebbot to factory settings
Hi bgreenejr,
Are you referring to the BIOS or OS?
If you’re referring to the BIOS settings, you can do this by accessing it and selecting "set to factory default" from the menu. The most common way to access it is by pressing the DEL button upon boot up; there are however, a lot of branded PC and laptops may use a different button like F2 or F12, etc; if you’re BIOS is locked, of course you’ll need the password to log-in.
Another and common method of resetting it to factory default is by shorting the CMOS reset jumper located in your motherboard, usually it’s the closest jumper to the battery or the CMOS chip. This does not require any password, actually this is the method used if you forget your BIOS password. I would suggest that you consult your motherboard or computer’s documentation on how to locate the CMOS reset jumper on it.
If you are referring you your operating system, the only sure way to reset it to default settings is if you do a clean install, that means re-formatting your pc and re-doing everything again, kinda messy, unless you can do a system restore that would revert it back to the original date and time when you first install the system, . Hope this helps
Cheers and best regards,
May 06, 2008 | Computers & Internet
Dell OptiPlex GX110 PC Desktop Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
