Weather King 12AJA4801AH Air Conditioner Logo
Question about Weather King 12AJA4801AH Air Conditioner
Weather king dual zone
Posted by larryfry on
Anonymous
DUAL ZONE MEANS THE CONDENSER HAS A WAY TO REDUCE HP. SEVERALWAYS TO DO THIS. ALL DUAL ZONE MEANS YOU CAN SEPERATE AREAS OF YOPUR HOUS WIT 2 T-STATS. WHEN YOU GO TO BED AT NIGHT YOU CAN SHUT THE MAIN HOUSE DOWN. A DAMPER CLOSES AND THE COMPRESSOR GOES TO A LOWER OUTPUT TO SAVE MONEY. I HAVE BEEN IN THE BUISNESS FOR 40 YEARS. SEVERAL PROBLEMS FROM COMPRESSOR FAILURE TO THE CONTROL MOTHER BOARD FAILURE ALL AD UP TO MORE MONEY THAN YOU WILL EVER SAVE ,,, TOO MANY GADGETS TO0 GO BAD.
Posted on Sep 27, 2007
Weather King A/C comes on outside but no air blowing through the vents inside
So, blower motor issue? Turn tstat fan to on. Possibly has a capacitor that is bad, motor could be bad, relay could be bad, sequencer or board. You need a voltage meter.
Capacitor
the capacitor is a 30/3 370vac
I need a Weather King A/C repairman for my area. I live in New Orleans, La.
any AC Tech (in phone book) worth his/her salt will be able to repair your ac - but - you should be able to find a Weather King tech via the phone book or internet.
Good Luck!
Weather King split AC system.
Turn the power off ,and check all the electrical connections for loose connection or wires. also make sure these are slow blown timmed delayed and not one-time fuses. Thank-you verymuch!
Top Weather King Heating & Cooling Experts
Robert
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
