This comes straight from the service manual:
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. (they can easily become partially disconnected)
3 Check that the memory module in the Formatter is installed correctly.
4 Check that the connections between the Formatter are not damaged and are correctly connected.
5 Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
1st If the System Error continues, replace the Main PCA
2nd If the System Error continues, replace the Formatter
3rd If the System Error continues, replace the Front Panel
SOURCE: My printer does the same thing
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate
Parameters
Information
It is possible to lower the transmission speed of the initial handshake
of the HP Officejet 9100 to a lower value that may aid in compatibility
and resolve 223, 232, and 283 errors. The following steps will walk you
through configuring the setting. These are temporary settings. If the
unit loses power, the settings need to be reconfigured. From the front panel:
The screen will read Cfg param val: 26
Screen will read Test -001+
SOURCE: the z6100 42 inch plotter
Welcome to Fixya
The 08 code code means FRONT PANEL. The :11 is an action code requesting RESEAT, CLEAN. You should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which you can download at this site.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I AM GETING PROBLEM WTIH HP PLOTTER T1100, ERROR
Tech guys only:
Service station error..Remove right cover,
remove & take out service station, check any objects in service
station movement, remove motor clean entire unit with water you can find
out lot of ink inside & too dirty clean it allow to dry apply
grease for smooth movement( pl take care of pumping unit & tubes),
fix it back, perform service station test ( to enter in service mode
switch of the machine with power off button from front panel hold UP
arrow button & OK key button then which on the from front panel
button, wait till enter in service mode scroll to service station enter,
three options service station,primary motor and aerosol motor select
service station, enter wait till result papers on panel) best of luck...
