Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a cub cadet zero turn, runs fine but when I engage the blades on grass it bogs down and won't go fast at all.
Posted by Matt Dowdy on
Nova Buchanan
    New Friend:
  • 3 Answers
All all spindles well greased?
Posted on Jun 19, 2019
wayne joseph colley
    New Friend:
  • 33 Answers
Problem can be caused by dirty fuel (jets in carby blocked) need to clean carby or even put a kit through it.
Posted on Nov 30, 2013
3 Related Answers
Anonymous
  • 496 Answers
SOURCE: Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Posted on Aug 31, 2009
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: I aqm having difficulty with
Hi, it sounds like the something is wrong with the electric clutch. It has a brake built into it that is supposed to stop the blades when the clutch is disengaged.
The clutch has a rotor attached to the engine shaft. The coil is inside the rotor toward the engine. There's a clutch disc attached by leaf springs to the pulley for the belt that drives the blades. There's a brake ring around the disc. When the clutch is engaged, the disc moves away from the brake ring and is held tight to the rotor.
Posted on Apr 11, 2011
mike butler
  • 6468 Answers
SOURCE: Husqvarna zero turn mower backfires and stalls when mower blades on
sound like a carb problem clean the jets out
Posted on May 20, 2012
Troubleshooting
need govenor adjustment and throttle adjustment have to take in 60.00
Sep 04, 2014 | Cub Cadet Garden
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
656 people viewed this question
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Dennis Key
Dennis Key
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
