Question about Motorola Mag One BPR40 Two Way Radio
Green light stays on bpr40 - Motorola Mag One BPR40 Two Way Radio
eradiostore
  • Motorola Master
  • 1,658 Answers
If this is after programming your radio needs repaired. We see this when some BPR40s are reprogrammed. Take the radio to your local service center or send to a qualified repair center.
Posted on Dec 17, 2015
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
Mag one wont get reception
First you check the volume, turn the volume, then you check your speaker. If both are ok then you check QT and DQT. These character must be same.
Jan 14, 2014 | Motorola Mag One BPR40 Two Way Radio
Mt mag one bpr40 uhf 450/470 will receive but will not transmit. green light is on all the time
It probably has "busy channel inhibit" turned on in the menus, and the squelch is open, thus making it think there is a signal on the channel you're trying to use.
Sep 01, 2013 | Motorola Mag One Bpr40 Uhf 4w 8 Channel...
My mag one bpr40 will not transmit. the green light is on all the time. it will receive. how do i fix this problem
Green light coming on and staying on... Sadly nothing the end-user can do to alleviate this problem themselves. It is usually repairable by a trained/equipped repair facility.
Sep 01, 2013 | Motorola Mag One BPR40 Two Way Radio
Have two bpr40 need to find out the frequencys
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Aug 20, 2013 | Motorola Mag One BPR40 Two Way Radio
My BPR40 transmits to one radio but can't respond ?
Check your PL/DPL settings among the radios. You may not have them programmed the same as one another. PL (aka private line) blocks out other users who do not have the same code as one another. Your radio which receives could be set with no PL code and it receives and hears every thing, so it would hear the other two, but not talk to them if they have a PL code setting.
Another way to check this is typically the dealer who programmed them will have the side button directly under the PTT programmed for Monitor. If you press this button a short press you should temporarily go into "open squelch" and you would be able to hear everything on your frequency. Try pressing this button on one of your "two" radios and see if they can hear the "one" radio. If so, you know it is a programming issue. (provided the button is programmed to Monitor). If pressing the Monitor button does not allow temporary communication, you have another issue.
If the green light on the radio seems to come on and stay on continuously, the radio is in need of repair. (Average flat rate repair on tehese BPR40s are around $79 currently at many repair centers.)
Best regards.
Jan 14, 2013 | Motorola Mag One BPR40 Two Way Radio
The green light that indicates that some one it talking and goes red when you key always slays on
This is an indication of a receiver problem. Two things cause this. The receiver needs to be realigned or you have bad ceramic filters that need to be replaced.
Sep 12, 2011 | Motorola Mag One BPR40 Two Way Radio
Just got a Mag One BPR battery delivered to me and i put it on the charger. After about an hour the green light is on. I thought the battery needed to be charged for 8 hours the first time? Why the green...
The charger which comes with the BPR40 is a rapid charger. (The book doesn't indicate if it is a 90 min. or 3 hour charger.) None-the-less, your battery is fine. When your charger is displaying green it will continue to trickle (slow) charge the battery to keep it topped off, so to speak. The first 3 charge cycles you should leave the battery on the charger the full recommended time. On most Motorola radios it is 10-12 hours. This will assure your battery is charged to full capacity and initiated properly. In most cases, your traditional charging of the radio should be overnight. When you go to bed, put the radio to bed on the charger.
FYI: All batteries come from the factory with some charge in them. It is a small test charge to assure the battery's funcationality.
If for some reason after the first week or so, you think your battery or charger is not functioning properly, contact the dealer where you purchased the unit. They can replace it under warranty.
Best regards.
Dec 29, 2010 | Motorola Mag One BPR40 Two Way Radio
I have a set of 5 radios. One of the radios has the green light on all the time and is not hearing all transmissions.
The constant green light generally means the radio is in receive mode, or is receiving a transmission. You might check your antenna to be certain it is properly attached, is free from defect, and is seated properly in the antenna port. Also, just for test purposes, try your radio at different volume settings, as the on/off volume potentiometer might have a shorted or dead spot.
If none of the above solve the problem, your radio is likely in need of repair. (Typically around $69 flat rate) If your radio is still under warranty (1 year) return it to the dealer where you purchased it for warranty.
Best regards.
Dec 17, 2010 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
612 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
