Question about Vizio Televison & Video
The volume is not working on my vizio tv. I tried manually and with the remote. I can press the volume button one time up and it will go up all the way, I can press it one time down and it goes all the way down to 0. Manually does nothing at all. So I can watch tv at extremely loud full volume or no sound at all...very aggravating.
Posted by Bridgett on
GreenHotrod Hotrod
    Habit-Forming:
    New Friend:
  • 105 Answers
Reset TV to factory defaults and then update firmware
Posted on Oct 30, 2017
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Posted on Oct 25, 2008
Anonymous
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
Anonymous
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
Anonymous
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
Anonymous
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Code for TV/Video button on Dish remote will not change Vizio tv to other components.
Hi dclapper222, not all codes give our remotes full functionality; though we do have some other codes we can try!
A few of the codes for a Vizio TV that we have are 627, 66, 505, 222, 678, 232, and 458. You can find more codes or instructions at this link: http://www.dishnetwork.com/SupportSection/remote-setup. I have outlined the steps below to program your remote to your TV.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Hope that helped! Let me know here if you have any other questions!
Tommy Faust
DISH Network
Jun 18, 2011 | DISH Network IR Remote Control
Bought a vizio tv works good it but the volume control is real hard to get it to pick up every thing else works ok. It has the right code in.
Hey sherryg98, it sounds like you have a right code, but may not be a code to give full functionality as there are many codes for a Vizio TV.
You can check out this link for more info on codes: http://www.dishnetwork.com/SupportSection/remote-setup
Some codes you can try are 627, 766, 505, 006, 232, 458, 500, 670, 678. Depending on the model of your remote there may be different codes available. I've given the steps to address a remote below just in case.
If you need any further assistance let me know here or email me at [email protected]
Jun 15, 2011 | DISH Network IR Remote Control
I want to program my sony RMT-B107A remote to controll my Vizio tv and I can't find the codes, HELP!
I know that it has been a while since this question was originally asked, but I figured that I would share what worked for me.
Here is what worked for me: (RMT-B107A remote and Vizio TV)
1. With the TV on, Press and hold TV I/O button
2. Press 04 on the number keypad.
3. Press the TV I/O button and the TV should turn off
This method also allows me to control the volume on my Vizio. The TV input button did not work.
Jun 03, 2011 | Televison & Video
I have vizio tv and i wana use the dish remote for my tv 2 how 2 program?
Hello there! this is Kimberly Escobar with Dish Network customer support, just ran across your post and wanted to provide you with with information that will be helpful to you. To program your remote to your Vizio T.V you can try using some of the codes we have available that help the remote control functions of your T.V itself. For the Vizio brand one of the codes is 505. what you will need to do is press and hold the clear T.V button located on the upper left hand corner of your remote until all the other top buttons begin to light up, once they light up you let go of clear T.V button and enter the number 505 followed by the pound key (#) as soon as you press pound you will see the clear T.V button flash 3 times. You can can your volume or turning off and on the T.V it should work. For further assistance you should also find this link very helpful http://www.dishnetwork.com/SupportSection/remote-setup as well as contacting us directly. Hope this helps!
Jan 24, 2011 | DISH Network IR Remote Control
My friend has a Vizio model E470VA and Dish network. But the Dish remote will not control the volume / mute on the tv reliability. The on/off button works perfectly. Remote has been replaced also...
Hello, my name is Becki Barned, and I am with Dish Network customer service. To program the remote to a Vizio tv, there are a couple approaches that you may take. First is, follow this link: http://www.dishnetwork.com/SupportSection/power-scan-instructions which walks you through it. Or do these steps: 1. Hold down the TV mode button until all mode buttons at the top of the remote light up, then release. 2. Punch in the code 505. 3. Press the pound (#) button on the keypad. Use either of these, and that remote will work great! Just make sure after you get the volume working, that you press the SAT button on the remote! If you have any other questions, blog back, or you can find us on Twitter!!!!
Dec 18, 2010 | DISH Network IR Remote Control
Vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Apr 20, 2009 | Vizio VO47L 47 in. LCD TV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
111 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
