SOURCE: How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Best,
Dan
There is a slide switch on the front of the unit labeled "key lock" that if enabled disables input from all controls, including power off. Disabling the switch should allow you to power off
Thanks Problem solved!
