If your Samsung Galaxy Z Fold3 is not turning on, despite having a charged battery, there could be several possible reasons for this issue. Here are a few troubleshooting steps that you can try:
- Force restart the device: Press and hold the power button and volume down button for about 10 seconds. This should force the device to restart, and may help to resolve any software issues that are causing it to not turn on.
- Charge the device: Even if you believe the battery is charged, try charging the device for a while and see if it turns on. Sometimes the battery may not be fully charged, or there may be an issue with the charging port or cable.
- Check the display: If the inside screen is dark, try shining a bright light on it to see if you can see any faint images or icons. If the display is completely blank, there may be a hardware issue with the device that is preventing it from turning on.
- Boot into recovery mode: Press and hold the power button and volume up button to boot into recovery mode. If you can access this mode, try wiping the cache partition or performing a factory reset. However, note that this will erase all data on your device.
If none of these steps work, it may be necessary to contact Samsung support or take the device to an authorized repair center for further diagnosis and repair.
